Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505, EIGRP split horizon
I have a small environment that I wanted some redundancy in. It consists of two layer 3 switches that are connected with each other and they both connect to an ASA 5505, forming a triangle in logical architecture. EIGRP is running between all of them. Neighbor relationships form between each of the L3 switches and with the ASA, but when the cable between the two L3 switches is disconnected, routing between them does not pass through the ASA. I've bypassed this by issuing 'no split-horizon eigrp <AS>' on the SVI on the ASA that communicates with the L3 switches and the routing passes just fine. Everything works as intended... until the ASA reboots. For whatever reason that command is wiped from the SVI every time the ASA is rebooted. Even after a reboot, the startup config shows the command on the SVI, but it never gets loaded into the running config. Is this a bug? Or an intended feature? I'm running 9.1(1).
VIP Green
This does sound like a bug, though I have not been able to find any documentation on it.  Have you tried upgrading to the 9.1(3) version? could this be an option?
Please remember to rate and select a correct answer
Confirmed. 9.1(3) does the same thing. The split-horizon command shows in the startup config, but will not be loaded into the running config upon reload. I made sure to load 9.1(3), manually add the command onto the SVI, write the config and then reload. Upon rebooting into 9.1(3) again, the command is ignored.
VIP Green
is the ASA booting from the startup config or has the startup config file been changed?
show bootvar
BOOT variable = disk0:/asa913-k8.bin
Current BOOT variable = disk0:/asa913-k8.bin
CONFIG_FILE variable =
Current CONFIG_FILE variable =
VIP Green
could you check the configuration register, if it is not set to 0x1 then you need to change it to this value.
show version | in register
config-register 0x1
303
