Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 Flash Erased
Hello
We had several problems with the ASA, continues to reboot and not able to locate the image file we erased the Flash, not the best idea we had this year.
Can you help us bring this dead piece of metal from the grave to a working ASA again.
Hello
We tried the link and getting this
Forbidden File or Application
Hall of Fame Super Silver
Substitute "customer" for "partner" in the above URL. i.e.:
http://www.cisco.com/en/US/customer/docs/security/asa/asa82/configuration/guide/admin_trouble.html#wp1076206
When someone with partner access posts a cisco.com URL it will often default to partner view. 98% of the content is equally available from customer view.
Silver
This section describes how to load a software image to an ASA from the ROM monitor mode using TFTP.
To load a software image to an ASA, perform the following steps:
Step 1          Connect to the ASA console port according to the instructions in "Accessing the Command-Line Interface" section.
Step 2          Power off the ASA, and then power it on.
Step 3          During startup, press the Escape key when you are prompted to enter ROMMON mode.
Step 4          In ROMMOM mode, define the interface settings to the ASA, including the IP address, TFTP server address, gateway address, software image file, and port, as follows:
rommon #1> ADDRESS=10.132.44.177
rommon #2> SERVER=10.129.0.30
rommon #3> GATEWAY=10.132.44.1
rommon #4> IMAGE=f1/asa800-232-k8.bin
rommon #5> PORT=Ethernet0/0
Ethernet0/0
Link is UP
MAC Address: 0012.d949.15b8
Note          Be sure that the connection to the network already exists.
Step 5          To validate your settings, enter the set command.
rommon #6> set
ROMMON Variable Settings:
  SERVER=10.129.0.30
  GATEWAY=10.132.44.1
  PORT=Ethernet0/0
  VLAN=untagged
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
Step 6          Ping the TFTP server by entering the ping server command.
rommon #7> ping server
Sending 20, 100-byte ICMP Echoes to server 10.129.0.30, timeout is 4 seconds:
Success rate is 100 percent (20/20)
Step 7          Load the software image by entering the tftp command.
rommon #8> tftp
  SERVER=10.129.0.30
  GATEWAY=10.132.44.1
  PORT=Ethernet0/0
  VLAN=untagged
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
tftp f1/asa800-232-k8.bin@10.129.0.30 via 10.132.44.1
Received 14450688 bytes
Launching TFTP Image...
Cisco PIX Security Appliance admin loader (3.0) #0: Mon Mar  5 16:00:07 MST 2007
Loading...
After the software image is successfully loaded, the adaptive security appliance automatically exits ROMMOM mode.
Step 8          To verify that the correct software image has been loaded into the adaptive security appliance, check the version in the adaptive security appliance by entering the following command:
hostname> show version
Value our effort and rate the assistance!
260
