ASA 5505 incoming traffic issue #2 (continue)
rashev_kamen
Is anybody can figure out why the port mapped traffic like (smtp,www,RDP) is not going to the server Zeus. I guess is something wrong with the AAA access-list.
Thanks, for the help!
hostname ASA
names
name 10.100.50.172 Zeus
interface Vlan1
nameif inside
security-level 100
ip address 10.100.86.1 255.255.0.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address xxx.yyy.15.10 255.255.255.248
ospf cost 10
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa802-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name foods.com
object-group service VDC
description Video Conferencing
service-object tcp source range 3230 3238 range 3230 3238
service-object tcp eq h323
service-object udp source range 3230 3258 range 3230 3258
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq www
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq smtp
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq 3389
access-list out_in extended permit object-group VDC any host xxx.yyy.15.10
access-list AAA extended permit tcp host xxx.yyy.15.10 host Zeus eq 3389
access-list AAA extended permit tcp host xxx.yyy.15.10 host Zeus eq smtp
access-list AAA extended permit tcp host xxx.yyy.15.10 host Zeus eq www
access-list AAA extended permit tcp host xxx.yyy.15.10 host Zeus eq pptp
access-list AAA extended permit object-group VDC host xxx.yyy.15.10 host 10.100
86.5
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.100.0.0 255.255.0.0
static (inside,outside) interface access-list AAA
access-group out_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.yyy.15.9 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.100.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet 10.100.0.0 255.255.0.0 inside
telnet timeout 30
ssh timeout 5
console timeout 30
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
service-policy global_policy global
Farrukh Haroon
You are right, the ACL is from the perspective of the ASA, it should be the reverse:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/cfgnat.html#wp1043281
Farrukh
I have replaced the the statements in the AAA access-list with
#access-list AAA extended permit tcp host Zeus eq smtp host xxx.yyy.15.10 eq smtp
But it still not working. What I'm doing wrong?
Run the packet-tracer command and see what is going wrong.
Farrukh
Replace "xxx.yyy.15.10" with the word "interface" in your policy acl.
