Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505 incoming traffic issue
I have an issue getting email through the Cisco ASA to our email server 10.100.50.172 255.255.0.0
Everything else is working. We have internet. All outgoin traffic is OK. Is anybody see what's wrong. Thanks,
ASA Version 8.0(2)
hostname ASA
names
interface Vlan1
nameif inside
security-level 100
ip address 10.100.86.1 255.255.0.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address xxx.yyy.15.10 255.255.255.248
ospf cost 10
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa802-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name ABC.com
object-group service VideoFlow
service-object tcp range 3230 3253
service-object tcp eq h323
service-object udp range 3230 3235
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq www
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq https
access-list out_in extended permit tcp any host xxx.yyy.15.10 eq smtp
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.100.0.0 255.255.0.0
static (inside,outside) xxx.yyy.15.10 10.100.50.172 netmask 255.255.255.255
access-group out_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.yyy.15.9 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.100.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet 10.100.0.0 255.255.0.0 inside
telnet timeout 30
ssh timeout 5
console timeout 30
dhcpd auto_config outside
no threat-detection basic-threat
no threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
service-policy global_policy global
prompt hostname context
1 ACCEPTED SOLUTION
Green
Re: ASA 5505 incoming traffic issue
Change
to
static (inside,outside) interface 10.100.50.172 netmask 255.255.255.255
Try disabling inspect esmtp from your default-inspection-traffic rule.
From config mode:
no inspect esmtp
I hope it helps .. please rate helpful posts
Green
Change
to
if you are using the same public IP the one on global (outside)
you'd better try to make a static PAT to forward the smtp for example in the inbound direction to you internal mail server
rate if worked please,
Community Member
Great! It's working.
But I would like to configure xxx.yyy.15.10 for my emai traffic and xxx.yyy.15.11 for video conferencing? How I suppose to do it now? What is the best way to configure this?
Green
no static (inside,outside) interface 10.100.50.172 netmask 255.255.255.255
static (inside,outside) tcp interface smtp 10.100.50.172 smtp netmask 255.255.255.255
then add another static with the new port and new destination address...example....
static (inside,outside) interface netmask 255.255.255.255
Community Member
This is fine if we have just one protocol, but in my case I need to open tcp 3230-3238, udp 3230-3258. And with PAT I can't use object groups. How I can resolve this? Thanks for the help!
first i guess the way i have sent you solved your problem i mean static PAT ?
secondley for VOIP and vedio you dont have to open these udp ports, what you have to do first make (access lists) and static PAT for the tcp signaling protocols only
then make a policy inspection for that vedio traffic for example H323
if you gonna open all these udp port as u said then you dont need firewall because this security will be so weak..
thanks and let me know if worked
Marwan
Community Member
I totally agree with you, but this is a customer firewall and the management is asking me to open all these ports. How I can do this just with one IP address xxx.yyy.15.10? If it's not possibel, what will be the config if we get second IP address.
Why with ASA the command
is not working and need to be replaced with
It's working on another ASA5510.
about the static nat if you static IP address it supposed to work, unless u have DHCP address from you ISP in this case the interface word will be must
and about opening ports with pat could you send me the case in more details and what the required result
Community Member
This is what I need exactly to do:
I need to forward all HTTP, HTTPS, SMTP traffic to 10.100.50.72 and all the packets on the range of tcp 3230-3238 and udp ports 3230-3258 and h323 to 10.100.50.70 (this is for video conferencing, it's not cisco, not sure what kind).
We have just one IP address xxx.yyy.15.10? Can I do this?
With my firs config that I had posted niether one was working.When I replaced
with
I got it working for 10.100.50.172.
Why the first one is not working here, no idea. It's working on another ASA5510.
Can I forward now the video conferencing traffic to 10.100.50.170.
Also if it's not possible what will be the config if we get a second IP address.
i am not sure but try this method and rate if helpful
make a NAMED ACL which contains in its ACE
source of any and distination should be 10.100.50.172
and with the acl entry make the http, https and range of udp and so on make all the required entries
than
go to the static pat stage
remove th old one
and make new one that should be like
static (inside, outside) xx.yyy access-list (ACL NAME)
and let me know
Community Member
This is what I'm getting when I try this:
ASA(config)# static (inside,outside) interface access-list ABC
WARNING: static redireting all traffics at outside interface;
WARNING: all services terminating at outside interface are disabled.
ERROR: Invalid netmask with interface option
What I'M putting wrong? I tried with Netmask 255.255.255.255 option but I'm getting the same.
try to replacethe interface by the ip address u have and see what happen !
Community Member
When I tried this I'm getting:
RedRiverASA(config)# static (inside,outside) 209.155.15.10 access-list ABC
global address overlaps with mask
Usage: [no] static [(real_ifc, mapped_ifc)]
I tried also 209.155.15.11 and I get the same
Community Member
When I replaced the 'any' with the external IP address xxx.yyy.15.10 in the access list
#access-list AAA extended permit tcp host xxx.yyy.15.10 host 10.100.50.172 eq smtp
I was able to apply
#static (inside,outside) interface access-list AAA
or
#static (inside,outside) xxx.yyy.15.10 access-list AAA
But either one I use the traffic is not getting in again.
i think better to try the simplist way
which as follow
first make you global nat with interface or ip address given to u by the ISP
then make a normal simple static nat
without puting any tcp or udp to translate evry thing in inbound direction to the internal server
finaly make an access-list to limit what is permited from any source to ur nated outside interface ip
in this case with static nat u gonna translte evry thing comes to ur public ip adddress to ur inside server
then by the ACL u gonna fillter what permited and whats not
and let me know
good luck
keep it as simple as possible
by the way dont forget to remove the old nat config!
498
