05-18-2012 03:12 AM - edited 03-11-2019 04:08 PM
Having a bizarre issue that's beyond my knowledge. I configured the ASA 5505 for an IPSEC tunnel. Regardless of what remote site a user tunnels from, the tunnel comes up, both PHASE 1 and PHASE 2. From some sites, the user can successfully ping the office network resources behind the ASA, but for others, from troubleshooting, it seems traffic from the remote end can reach the office network resources, but the the office network resources cannot get past the ASA and not reach the remote end. Logging is no help as I cannot see any traffic dropped by the firewall. It's bizarre as some sites work - where traffic is bi-drectional over the tunnel, and others do not, but for those remote sites where it doesn't work, the problem looks like behind the ASA - where traffic is one-way over the tunnel.
Has anyone seen this before? And advise a corrective action?
Solved! Go to Solution.
05-18-2012 10:26 PM
Try getting rid of this command
no crypto isakmp nat-traversal
05-18-2012 05:09 AM
Should be something to do with configuration .
Please post both end configuration so that someone can take a look.
Also mention which site is able to communicate .
Ajay
05-18-2012 07:50 AM
Many thanks for the reply. I've pasted the config below. However, it's difficult to provide information from the remote sites as they have differing external IP's.
: Saved
ASA Version 8.0(2)
hostname ASA-Avaya
domain-name *********.***
enable password ************* encrypted
names
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan10
nameif inside
security-level 100
ip address 192.168.101.115 255.255.0.0
interface Vlan20
nameif outside
security-level 50
ip address ************* 255.255.255.248
interface Ethernet0/0
switchport access vlan 20
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
passwd ************* encrypted
boot system disk0:/\asa802-k8.bin
boot system disk0:/asa802-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name *************.***
access-list inside_nat0_outbound extended permit icmp any any
access-list inside_nat0_outbound extended permit ip any any
access-list inside_nat0_outbound extended permit ip any 192.168.106.0 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-list outside_access_in extended permit ip any any
access-list avaya_splitTunnelAcl standard permit any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool avaya-pool 192.168.106.1-192.168.106.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 ************* 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http ************* 255.255.255.255 outside
http 192.168.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
ssh scopy enable
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
group-policy avaya internal
group-policy avaya attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value avaya_splitTunnelAcl
username admin password ************* encrypted privilege 15
username avaya password ************* encrypted privilege 0
username avaya attributes
vpn-group-policy avaya
tunnel-group avaya type remote-access
tunnel-group avaya general-attributes
address-pool avaya-pool
default-group-policy avaya
tunnel-group avaya ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:*************
: end
05-18-2012 09:50 PM
I would disable the split tunel from the policy just to clean the config as it is not need it.
Now the configuration looks fine, I would say it something besides the ASA but for that we got to be completely sure about it.
I would like you to run captures while you attempt to connect on the other site...
access-list capin permit ip host x.x.x.x (local pool IP) y.y.y.y(internal host IP)
access-list capin permit ip host y.y.y.y host x.x.x.x
capture capin access-list capin interface inside
capture asp type asp-drop all
Then try to connect to an internal host...
Afterwards do a sh cap capin
and a Show cap asp
Please send us the information.
Do rate the helpful posts
Julio
05-18-2012 10:26 PM
