ASA 5505 ISP dhcp issue
I have an ASA 5505 at a small site and the ISP assigns my outside interface an IP address and default gateway. However, when power goes out (I know I need to get battery backup), my ASA loses its IP address and default gateway. It will not get it back automatically.
Is there a command on the ASA to request the dhcp address again from the ISP versus having to reboot it every time? I have looked for commands to use with no success...
Re: ASA 5505 ISP dhcp issue
Have you tried to remove/add the ip address command from the VLAN interface when the problem occurs? For example, issue a "no ip address dhcp setroute" and then "ip address dhcp setroute" under the corresponding VLAN interface.
Yes - I have tried to shut down and no shut the interface, I have tried to remove the "IP address dhcp set route" command with no success. I am using version 8.0.
Please let me know the exact version of code you are running. Thank you.
it is 8.0(2)
asa802-k8.bin
392
