ASA 5505 Issue
I have an ASA 5505 and setup a outside interface that has ip address dhcp for my internet connection. I am running dhcp on this box for my inside network. I ping the ip addresses on the internet however I keep getting these errors when I try to browse the internet from the inside network.
6 Nov 15 2009 14:15:38 110002 192.168.1.10 2069 Failed to locate egress interface for TCP from inside:192.168.1.10/2069 to 77.178.232.99/80
6 Nov 15 2009 14:25:56 305012 192.168.1.10 58055 86.16.2.106 1038 Teardown dynamic UDP translation from inside:192.168.1.10/58055 to outside:88.16.2.106/1038 duration 0:00:30
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: ASA 5505 Issue
Charlie
So the outside interface is up and getting an IP address ?
If so can you check your routing table - you should have a default-route in their pointing to the next-hop ISP address.
Jon
Re: ASA 5505 Issue
Charlie
Jon
Re: ASA 5505 Issue
Got it everything is working great now. I can't belive I missed that.
2314
