Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505 Lab with Layer 3 Switch
Hello - Any help will be greatly appericated.   I have a lab environment that I am trying to figure out.  I'm using GNS3, within GSN3 I have my ISP as the cloud and an ASA 5505 connected to a Layer 3 Switch and one host connect to the L3 Switch.  The Layer 3 Switch had ip routing enable and so my host is getting an address from the layer 3 device.   From the host, I can ping the ASA inside interface, but I cannot ping 4.2.2.2 from the host.  Below is a config setup for the ASA and Layer 3 Switch.
ASA
interface GigabitEthernet0
nameif outside
security-level 0
ip address 192.168.137.2 255.255.255.0
interface GigabitEthernet1
nameif inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
object network VLAN10
range 192.168.102.0 192.168.102.255
object service WEB
service tcp source eq www
object network GW
host 192.168.137.1
object service web
object network Router
host 192.168.100.1
object network 192.168.102.3
host 192.168.102.3
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.137.1 1
route inside 192.168.0.0 255.255.0.0 192.168.100.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.137.1 255.255.255.255 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
hostname L3Switch
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip dhcp use vrf connected
ip dhcp pool vlan10
   network 192.168.102.0 255.255.255.0
   default-router 192.168.102.1
no ip domain lookup
ip domain name lab.local
archive
log config
  hidekeys
vlan internal allocation policy ascending
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no switchport
ip address 192.168.100.2 255.255.255.0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
switchport access vlan 10
interface FastEthernet1/15
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.102.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.100.1
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
1 ACCEPTED SOLUTION
On 8.3 it is not mandatory to have a nat rule.
Now you need it as it's the only way to go out to the internet I would guess, then yes you are missing the NAT
Just do the following
Nat (inside,outside) source dynamic any interface
By the way read the following documment, It will help you for future issues:
https://supportforums.cisco.com/docs/DOC-12690
Rate all the helpful posts, to the community that is a thanks
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Do the following on the ASA:
clear configure fixup
fixup protocol icmp
And then try to ping
This will make the ICMP a stateful protocols so the incoming traffic will be allowed by default.
Julio
Julio Carvajal
Community Member
Thanks, but that didn't work.  I think it has to do with my NAT.  This is version 8.4(2) and the NAT options are getting confusing.
I tried the following commands for NAT, but 8.4(2) did not take the commands
nat (inside) 1 192.168.100.0 255.255.255.0
global (outside) 1 interface
Julio Carvajal
Community Member
Thank you sir.  5 star help.
Thanks for the rating,
Any other query regarding post 8.3 changes just let me know
Julio
Julio Carvajal
1924
