ASA 5505 NAT issue
I am trying to get a cisco asa 5505 up and running but every time I try to create a NAT for the servers, the NAT will not work and the server loses communication. I have pasted my running-config in hopes that it's something simple that I have overlooked.
Thank you in advanced for any help!
: Saved
: Written by enable_15 at 02:51:41.439 CDT Tue Mar 25 2014
ASA Version 9.1(4)
hostname goode-ciscoasa
domain-name goodeco.int
enable password zaPfq2iO5oGgF4HK encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.217 255.255.255.240
boot system disk0:/asa914-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network EXCHANGE1
host 192.168.1.25
description EXCHANGE1
object network EXCHANGE2
host 192.168.1.26
description EXCHANGE2
object network EXCHANGEHOSTED
host 192.168.1.121
description EXCHANGEHOSTED
object network QUICKBOOKS
host 192.168.1.30
description QUICKBOOKS
object network FILESERVER
host 192.168.1.128
description FILESERVER
object service CRM-42001
service tcp destination eq 42001
 description CRM-42001
object service RDP
service tcp destination eq 3389
 description RDP
object-group service EXCHANGE-PORTS tcp
description imap
port-object eq www
port-object eq https
port-object eq 55
port-object eq imap4
access-list global_access extended permit ip 192.168.1.0 255.255.255.0 any
access-list global_access extended permit tcp any object EXCHANGE1 object-group EXCHANGE-PORTS
access-list global_access extended permit tcp any object EXCHANGE2 object-group EXCHANGE-PORTS
access-list global_access extended permit tcp any object EXCHANGEHOSTED object-group EXCHANGE-PORTS
access-list global_access extended permit object CRM-42001 any object FILESERVER
access-list global_access extended permit object RDP any object QUICKBOOKS
access-list global_access extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-715.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
nat (inside,outside) static x.x.x.210
nat (inside,outside) static x.x.x.211
nat (inside,outside) static x.x.x.220
nat (inside,outside) static x.x.x.218
nat (inside,outside) static x.x.x.215
nat (inside,outside) after-auto source dynamic any interface
access-group global_access global
route outside 0.0.0.0 0.0.0.0 x.x.x.222 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:5a058cefae4ff01b835ba396ae49039e
: end
Bronze
try a clear xlate for a
try a clear xlate for a particular static NAT after you appliy it
Bronze
Your config is a little
Your config is a little unusual in that you're using a single access-list globally on both your interfaces, but I can't see anything obvious that shouldn't keep it from working.  The "packet-tracer" command can be exceptionally useful in situations like this, so if the clear xlate doesn't help I'd try that.
40
