Asa 5505 newbie question (outside static and NAT)
Hi everybody,
First of all let me tell you that I'm totally new with Cisco firewalls. I have experience for Watchguard only.
I need to configure firewall to use static IP for outside network. With wizard I can configure ASA to use DHCP for outside network and everything goes fine but when I try to configure ASA to use static IP I can't connect to outside world anymore.
There is a router from ISP between ASA and internet and it uses static IP 81.209.97.9. I need to configure ASA to use IP 81.209.97.10 for outside interface.
Can you tell me the steps to do this? Can it be done in ASDM or do I need console connetion? Should I create static route between router and firewall or how do I tell firewall the IP of the router?
Juha
1 REPLY
Re: Asa 5505 newbie question (outside static and NAT)
Just found this link. Very simple and easy to follow. Only 6 steps.
http://ezinearticles.com/?Basic-Configuration-Tutorial-For-the-Cisco-ASA-5505-Firewall&id=1681858
You basically need the following.
route
permission
translation
to allow traffic through any firewall.
-KS
186
