ASA 5505 no able to connect from outside
                   I able to access internet but unable to connect to tghe servers behind the ASA. I can ping the router but I cannot ping the outside addresses i assigned to the servers. I want to use rdp to connect to the servers inside from the outside...HELP!
ASA Version 8.2(5)
hostname Kronos-Router
domain-name VIBES.Com
enable password DfAs0PFRiL encrypted
passwd DfAs0PFRiL encrypted
names
name 10.128.x.x MDS
name 10.128.x.x RouterAddress
name 10.128.x.x StaticGateway
name 192.168.x.x MDS_Server
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.x.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address RouterAddress 255.255.255.0
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server MDS_Server
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service RDP tcp
port-object eq 3389
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_TCP_0 tcp
group-object RDP
port-object eq www
port-object eq https
access-list Inside extended permit icmp host MDS_Server host MDS
access-list inside extended permit tcp any host MDS eq 3389
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list outside_access_in extended permit tcp any interface outside eq 10201
access-list outside_access_in extended permit tcp any any
access-list outside extended permit tcp any interface inside eq 3389
access-list outside_access_in_1 extended permit tcp any host MDS object-group DM_INLINE_TCP_0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.x.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3389 MDS_Server 3389 netmask 255.255.255.255
static (outside,inside) tcp MDS_Server 10201 MDS 10201 netmask 255.255.255.255
static (inside,outside) MDS MDS_Server netmask 255.255.255.255
router rip
route outside 0.0.0.0 0.0.0.0 StaticGateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http server session-timeout 15
http 192.168.x.0 255.255.255.0 inside
snmp-server host inside MDS_Server poll community ***** version 2c
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp inside
sysopt noproxyarp outside
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca server
shutdown
telnet 192.168.x.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 15
dhcpd auto_config outside
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics host
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server MDS_Server source inside prefer
webvpn
username cisco password miP9X7Qu1 encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:3f58ff817809eec74bdb046658ced63a
: end
Everyone's tags (7)
1 ACCEPTED SOLUTION
Super Bronze
I am not sure if this ASA is behind another NAT device that is connected to the Internet or if this is some internal firewall or just a lab setup.
Seems to me that your main problem is that you have not attached any ACL to the external interface to allow this traffic.
Would seem to that you would only need the following "static" command of the ones you have listed.
You should then build an ACL to allow the traffic to this server for the required ports
access-list OUTSIDE-IN permit icmp any host echo
access-list OUTSIDE-IN permit tcmp any host eq 3389
access-list OUTSIDE-IN permit tcmp any host eq 10201
Then you would attach this ACL to the interface with the following command
access-group OUTSIDE-IN in interface outside
- Jouni
Super Bronze
- Jouni
Thanks JouniForss
I applied the changes and that correct the issue.
Also, I added the following line for the RDP connection:
access-list outside_access extended permit tcp any host object-group RDP
I am able to connect remotely to the server now.
222
