ASA-5505 no access from LAN to outside
Hi All: I'm a newbie Cisco user and seem to have FUBAR'd my router config. I have a single LAN (192.168.21/24) with a single public server and two VPNs. After configuration of the VPNs I can no longer reach anything outside from the LAN. Servers inside the LAN can't ping or resolve external IPs.
I keep staring at the config but I don't see what's blocking the internal network from connecting to the outside world?
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password RQPm7xkzY.37Q.Ne encrypted
passwd RQPm7xkzY.37Q.Ne encrypted
names
name 192.168.22.0 vpn1
name 192.168.21.10 server2
name zzz.216.245.245 server2-public
name 192.168.21.51 server1
interface Vlan1
nameif inside
security-level 100
ip address 192.168.21.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address zzz.216.245.242 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object-group service remotedesktop tcp
port-object eq 3389
object-group service DM_INLINE_TCP_0 tcp
group-object remotedesktop
port-object eq www
port-object eq https
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
protocol-object icmp
protocol-object tcp
access-list outside_access_in extended permit tcp any host server2-public object-group DM_INLINE_TCP_0
access-list outside_access_in extended permit ip any host server2
access-list outside_cryptomap extended permit ip 192.168.21.0 255.255.255.0 vpn2.20.8.192 255.255.255.224
access-list outside_cryptomap extended permit tcp 192.168.21.0 255.255.255.0 vpn2.20.8.192 255.255.255.224
access-list outside_cryptomap extended permit icmp 192.168.21.0 255.255.255.0 vpn2.20.8.192 255.255.255.224
access-list outside_cryptomap extended permit udp 192.168.21.0 255.255.255.0 vpn2.20.8.192 255.255.255.224
access-list outside_cryptomap_1 extended permit object-group DM_INLINE_PROTOCOL_2 192.168.21.0 255.255.255.0 vpn1 255.255.255.0
access-list NONAT extended permit ip 192.168.21.0 255.255.255.0 vpn2 255.255.255.224
access-list NONAT extended permit ip 192.168.21.0 255.255.255.0 vpn1 255.255.255.0
access-list outside_cryptomap_2 extended permit ip 192.168.21.0 255.255.255.0 vpn1 255.255.255.0
access-list inside_access_in extended permit tcp host server2 192.168.21.0 255.255.255.0 inactive
access-list inside_access_in extended permit tcp host server2 any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool clientVPN 192.168.19.10-192.168.19.20 mask 255.255.255.248
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 server2-public
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) server2-public server2 netmask 255.255.255.255
static (outside,inside) server2 server2-public netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 zzz.216.245.241 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.21.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map1 1 match address outside_cryptomap
crypto map outside_map1 1 set pfs group5
crypto map outside_map1 1 set peer zzz.198.199.249
crypto map outside_map1 1 set transform-set ESP-AES-256-SHA
crypto map outside_map1 1 set nat-t-disable
crypto map outside_map1 2 match address outside_cryptomap_1
crypto map outside_map1 2 set pfs group5
crypto map outside_map1 2 set peer xxx.74.200.198
crypto map outside_map1 2 set transform-set ESP-AES-256-SHA
crypto map outside_map1 2 set nat-t-disable
crypto map outside_map1 3 match address outside_cryptomap_2
crypto map outside_map1 3 set pfs group5
crypto map outside_map1 3 set peer yyy.86.176.218
crypto map outside_map1 3 set transform-set ESP-AES-128-SHA
crypto map outside_map1 3 set nat-t-disable
crypto map outside_map1 interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption aes
hash sha
group 5
lifetime 28800
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 20
encryption aes
hash sha
group 5
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 40
encryption aes
hash sha
group 2
lifetime 28800
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 60
ssh version 2
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 192.168.21.200-192.168.21.220 inside
dhcpd dns 192.168.21.21 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy admins internal
group-policy admins attributes
vpn-tunnel-protocol svc webvpn
webvpn
  url-list none
  svc ask enable
username user1 password BnP4oFE0lYFNYi3z encrypted privilege 0
username user1 attributes
vpn-group-policy admins
username admin1 password u6X0S5AMkqoOgmEg encrypted privilege 15
username admin1 attributes
service-type admin
username user2 password aZ5Twsd5dVRxpzaI encrypted privilege 0
username user2 attributes
username user3 password 8DT3.DeM1K6vSVsL encrypted privilege 0
username user3 attributes
tunnel-group admin type remote-access
tunnel-group admin general-attributes
address-pool clientVPN
default-group-policy admins
tunnel-group zzz.198.199.249 type ipsec-l2l
tunnel-group zzz.198.199.249 ipsec-attributes
pre-shared-key *
tunnel-group xxx.74.200.198 type ipsec-l2l
tunnel-group xxx.74.200.198 ipsec-attributes
pre-shared-key *
tunnel-group yyy.86.176.218 type ipsec-l2l
tunnel-group yyy.86.176.218 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
Cryptochecksum:96ef72aff7d98c9b62813cc932654157
: end
asdm location vpn2.16.102.32 255.255.255.224 inside
asdm location vpn1 255.255.255.0 inside
asdm location vpn2 255.255.255.224 inside
asdm location 192.168.19.0 255.255.255.0 inside
asdm location 192.168.21.224 255.255.255.248 inside
asdm location server2 255.255.255.255 inside
asdm location server2-public 255.255.255.255 inside
asdm location server1 255.255.255.255 inside
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Normally an ASA permits traffic by default from a higher security interface to a lower one (i.e., inside to outside).
However once you put an access-list on the inside interface, there is an implicit deny added for that interface once traffic has been compared to the access-list entries. So,
...tells the ASA to allow only server2 (192.168.21.10) traffic. All other traffic into the inside interface will be denied.
Thanks Marvin: So, I'm not sure why I added that ACL for server2...but having disabled it, I still can't seem to get any traffic from inside the network through the default IF. I tried adding a new rule to the inside IF allowing any-any, but that didn't work either.
But then I noticed that there was an implicit rule for IPv6 traffic that said "Any less secure network" as the destination, and it couldn't be edited in the ASDM GUI...but that didn't appear in the IPv4 "inside" Access Rules...so I deleted each disabled access rule one-by-one, and after deleting the last one, the implicit rule popped back up and everything started working...
thanks for putting me on the correct path!
You're welcome. Glad it helped.
213
