ASA 5505: passing port through
I have an ASA 5505 I am wanting to use in lieu of a tired old MS ISA Server. I have as a public address 10.1.1.210 for network 10.1.1.0/24.
I have on the private side 10.150.8.4 255.255.255.248 with network DG 10.150.8.254. I need to allow TCP Port 300 in and out and UDC Port 300 in and out.
I can ping both the default gateway and the host on the public side (10.1.1.200), but the application program ( a financial app) which requires port 300 at both sides of the interface will not work.
I feel I am missing something fundamental here. I set up the ISA server (on Windows 2000 no less about 8 years ago - but I can't set up the ASA 5505 even though I have eight VPN using same running to a ASA 5510 all of which I set up)
My IPV4 (that is all thats used here) 1, 2, and 3 inside are: (using the graphic firewall rules section)
          any outside-network/24 tcp      Permit
          any outside-network/24 udp      Permit
          any outside-network/24 ip         Permit
          any     any                   ip         Deny
and outside
          any     any                   tcp       Permit
          any     any                   udp      Permit
          any  inside-network/21  ip         Permit
          any     any                   ip         Deny
The CLI reads (for the ACL)
access-list TCP_300 extended permit tcp any eq 300 any
access-list UDP_300 extended permit udp any eq 300 any
access-list outside_access_in extended permit tcp any any
access-list outside_access_in extended permit udp any any
access-list outside_access_in extended permit ip any 10.15.8.0 255.255.248.0
access-list inside_access_in extended permit tcp any 10.1.1.0 255.255.255.0
access-list inside_access_in extended permit udp any 10.1.1.0 255.255.255.0
access-list inside_access_in extended permit ip any 10.1.1.0 255.255.255.0
I would thinnk this would render the firewall absolutely wide-open, but apparently not.
Larry Thompson
Super Bronze
I would first need to clarify a few things.
Is there some server/host on your LAN that needs to be accessed on port TCP/300 and UDP/300 or is it rather that some host on your LAN uses this as the destination port towards some external host?
Is this firewall directly on the edge of the Internet and have a public IP address itself?
What is the software level of the ASA?
- Jouni
The ASA version is 8.2(5)
The host is a SAMBA/AIX machine (works fine with present firewall) at adress 10.1.1.200 they are the only two devices on the "PUBLIC" side.
The PRIVATE side goes into a CISCO VPN router (10.150.8.254) and to IP addresses it routes to.
Basically it is a Home Banking program where intial contact is made (from the Private Side) some questions are answered at the Private Side host and then it is to pull up the data from the SAMBA/AIX device. This is where it fails. Because I am not altogether sure that there isn't another port or set of ports required.
I have examined my ISA server and most ports opened are typicals. I should think that the NetBIOS stuff would be irrelevant (shows what I get for thinking). The rules are basically allow all. If I could get the ASA to do that then I could winnow it down (perhaps).
Hope this helps, thanks for your time.
Larry Thompson
Super Bronze
Would it be possible to see the current ASA configurations?
Is there any need to perform NAT between these 2 ASA interfaces (Private / Public) ?
- Jouni
Here is the config:
Result of the command: "sho config"
: Saved
: Written by enable_15 at 19:32:30.659 CDT Wed Aug 27 2008
ASA Version 8.2(5)
hostname Home-Banking
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.150.8.4 255.255.248.0
interface Vlan2
nameif outside
security-level 0
ip address 10.1.1.210 255.255.255.0
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
access-list outside_access_in extended permit ip any 10.150.8.0 255.255.248.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route inside 0.0.0.0 0.0.0.0 10.150.8.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.1.1.0 255.255.255.0 outside
http 10.150.8.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:2c2400e3cbcf5bc18a273f4ef46942d9
They do NAT (so does the ISA server I believe), perhaps it just routes? It is dual homed as is the ASA
Super Bronze
Re: ASA 5505: passing port through
So the next thing to determine is that is there ANY connections that need to be opened specifically from the "outside" network towards the "inside" OR are ALL connections initiated formed from the "inside"?
At the moment the NAT configurations only holds a Dynamic PAT from "inside" to "outside". Together with ACL configurations it means that any connections can be formed from "inside" to "outside" without any problems (or should be).
On the other hand, if there was to be some need to form a connection from "outside" to "inside", I mean initiated from "outside" to "inside" this would fail. This is because the Dynamic PAT configuration only enables one way connection initiation.
The best way to monitor what happens would probably be in your case to use ASDM and use its Monitor window to see what connections are getting blocked.
Naturally if you can say right away that there is some connection that need to be initiated through "outside" to "inside" it might be as easy as configuration a couple of Static PAT configurations.
By the way,
Which one is the correct mask. You have different masks on the "inside" network in your post. One has 10.150.8.0/29 and the other one has 10.150.8.0/21. The bigger network being in the actual configuration. In that case if the source of the connection were to fall into that network segment the connections would naturally fail because of the return traffic would never make it back.
EDIT: Some typos
- Jouni
200
