ASA 5505 Pleae help
I brought Firewall ASA5505
ASA5505-50-BUN-K9 “(is there possible to upgrade same device to “ASA5505-SEC-BUN-K9 “if yes then how)
I am new for Firewall
Now I tried through Cisco help / YouTube / Google etc.
i got internet after few changes also pinging local networks but can't ping/connect statics routes
1:- ASA 5505                            :- 10.172.0.1 /16
2:- internet router (Linksys)    : - 175.50.157.111/24
3:- GWAN Router (Cisco 881)  : - 175.50.157.1/24
4:- MS Server                              : - 10.175.0.5/16
Also other inside network pinging / internet working fine
But can’t ping Static routes
I need to connect Global network through GWAN Router (Cisco 881 /pstn modem)
Please help for Cisco ASDM 6.4 software
Thank you very much
Result of the command: "sh ip"
System IP Addresses:
Interface               Name                   IP address     Subnet mask     Method
Vlan1                   inside                 10.172.0.1     255.255.0.0     CONFIG
Vlan2                   outside               175.50.157.117 255.255.255.0   DHCP
Current IP Addresses:
Vlan1                   inside                 10.127.0.1     255.255.0.0     CONFIG
Result of the command: "sh route"
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 175.50.157.11 to network 0.0.0.0
C   175.50.157.0 255.255.255.0 is directly connected, outside
S   10.0.65.0 255.255.255.0 [1/0] via 175.50.157.1, outside
S   10.250.5.16 255.255.255.255 [1/0] via 175.50.157.1, outside
S   10.245.10.174 255.255.255.255 [1/0] via 175.50.157.1, outside
d*   0.0.0.0 0.0.0.0 [1/0] via 175.50.157.11, outside
Few more
1 REPLY
ASA 5505 Pleae help
Cisco ASA 5505 Appliance with 10-User Firewall License, 8 FE
ASA5505-BUN-K9
Cisco ASA 5505 Appliance with 50-User Firewall License, 8 FE
ASA5505-50-BUN-K9
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd8048dba8.html
Answer is - YES
I do not understand last question "Also other inside network pinging / internet working fine "
From where you are trying to ping and what ?
Ajay
303
