Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
asa 5505 PPTP from outside
ASA 5505 can not PPTP to cleint RAS servers
We have a problem using PPTP to reach cleint RAS servers from inside our network. EAch time we try to create a new PPTP connectiuon if fail to authticate.
Users from the outside can access our RAS server using PPTP from the outside fine though.
Please see the below config and let me know if you can see a problem??
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password h0lden encrypted
names
name 192.168.1.4 fixitserv4
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group 1
ip address pppoe setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq smtp
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq https
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq ftp
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq ftp-data
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq www
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq pptp
access-list ACLOUTSIDE extended permit tcp any host 203.222.69.26 eq pop3
access-list ACLOUTSIDE extended permit gre any any
access-list ACLOUTSIDE extended permit icmp any any echo-reply
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 dns
static (inside,outside) interface fixitserv4 netmask 255.255.255.255
access-group ACLOUTSIDE in interface outside
route outside 0.0.0.0 0.0.0.0 203.222.69.26 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group 1 request dialout pppoe
vpdn group 1 localname fixit-it2@connexus.net.au
vpdn group 1 ppp authentication chap
vpdn username fixit-it2.connexus.net.au password h0nda store-local
vpdn username fixit-it2@connexus.net.au password h0nda
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
inspect icmp error
inspect pptp
service-policy global_policy global
prompt hostname context
Cryptochecksum:04f0a79461c4fdb22c8427e9ef753577
: end
557
