ASA 5505 Problem
I am attempting to set up a ASA 5505 in a location and having some issues. I am using a PPPOE connection with ATT and everything seems to be good. I have a secure connection and can ping public IP's from the ASA. My internal network (10.104.0.0/24) on the otherhand cant seem to get out past the ASA. I believe its either a routing issue, or a NAT issue. Unfournatly ATT is being tip lipped about the default gateway of my public IP. If anyone has any ideas please let me know. Below is my configuration for the ASA.
: Saved
ASA Version 8.2(5)
hostname 104-ASA
enable password XXXXXXXXXX encrypted
passwdXXXXXXXXXXXXXXX encrypted
names
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
switchport access vlan 20
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan10
description EXTERNAL-NETWORK
nameif OUTSIDE
security-level 100
ip address pppoe setroute
interface Vlan20
description INTERNAL
nameif INTERNAL
security-level 100
ip address 10.104.0.1 255.255.255.0
ftp mode passive
access-list VPN-TRAFFIC extended permit ip 10.104.0.0 255.255.255.0 10.33.80.0 255.255.255.0
access-list NONAT-MIAMI extended permit ip 10.104.0.0 255.255.255.0 10.33.80.0 255.255.255.0
pager lines 24
mtu OUTSIDE 1500
mtu INTERNAL 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (OUTSIDE) 1 interface
nat (INTERNAL) 0 access-list NONAT-MIAMI
nat (INTERNAL) 1 0.0.0.0 0.0.0.0
route OUTSIDE 10.33.80.0 255.255.255.0 68.157.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set SECURE esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map MIAMI 10 match address VPN-TRAFFIC
crypto map MIAMI 10 set peer 23.24.X.X
crypto map MIAMI 10 set transform-set SECURE
crypto map MIAMI interface OUTSIDE
crypto isakmp enable OUTSIDE
crypto isakmp policy 5
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group INTERNET request dialout pppoe
vpdn group INTERNET localname agrotrade104@att.net
vpdn group INTERNET ppp authentication pap
vpdn username agrotrade104@att.net password ***** store-local
dhcpd dns 205.152.X.X 205.152.X.X
dhcpd address 10.104.0.25-10.104.0.50 INTERNAL
dhcpd enable INTERNAL
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group 23.24.X.X type ipsec-l2l
tunnel-group 23.24.X.X ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:b48a8a2ff31c98880dd163a53e4cabef
: end
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Purple
Re: ASA 5505 Problem
and not to forget: I you don't change the security-level you have to instruct the ASA that you want to allow traffic between interfaces with the same level. That's not allowed by default:
ASA(config)#same-security-traffic permit inter-interface
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Purple
interface Vlan10
  nameif OUTSIDE
  security-level 100
Using a security-level of 100 is quite uncommon, As this is the least secure interface it should be changed to "0".
Then, how do you test if you can reach the internet? Only with PING? Then you have to enable ICMP-inspection:
    inspect icmp
ASA 5505 Problem
Inside the ASA i can ping 8.8.8.8 and other public IPs, correct me if im wrong but that means that i have connection to the outside world. Unfournatly my private network (10.104.0.0/24) cannot ping or get out.
As for the security level association to my vlan, everything will be tightened down, and the security ACL's will be implemented once the system is up and running completely. If my security-level is something that is causing the issue i can lower the level but i dont believe that is a problem. Feel free to correct me if im wrong, i am fairly new to ASA's.
-chris
VIP Purple
What do you mean with that? Inside the ASA *is* the network 10.104.0.0/24, isn't it?
Well, up to now no one knows if a prison can be build without fences because no one has tried it before. It seems you are someone who would try it ... ;-)
The security-levels control which kind of security to apply for the traffic. And 100 for the outside interface is probably nothing that anyone have thought before.
But use the following command and paste the output. It simulates what the ASA would do with the traffic:
ASA# packet-tracer input INTERNAL tcp 10.104.0.10 1234 1.2.3.4 80
VIP Purple
Karsten
Thanks for the help that command saved the day!!
455
