ASA 5505 setup with DMZ (Exchange OWA)-outside(Netgea) - inside
I'm trying to setup a ASA VPN/firewall and not having much luck!!
I'm new to CISCO firewalls, but have experience with Microsoft networks (MCSE NT 4).
Anyway, what I'm trying to do is configure my inside network to connect the DMZ (web /ftp / OWA frontend) and enable all the OWA required ports.
I also want to direct all internet traffic via a netgear firewall and allow for the VPN connection to my inside network.
The setup is as follows:
inside IP range: 192.168.20.0
outside IP range: 10.0.10.0 - connects to netgear 10.0.10.1
DMZ IP (web server): 192.168.2.1
Finally, the VPN pool 192.168.3.100-192.168.3.150
Here is what I have now...
interface Vlan1
nameif INTERNAL
security-level 90
ip address 192.168.20.250 255.255.255.0
interface Vlan2
nameif EXTERNAL
security-level 0
ip address 10.0.10.2 255.255.255.0
interface Vlan12
no forward interface Vlan2
nameif DMZ
security-level 90
ip address 192.168.2.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 12
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
same-security-traffic permit inter-interface
access-list External_access_in extended permit tcp any host 10.0.10.1 eq www
access-list External_access_in extended permit tcp any host 10.0.10.1 eq ftp
access-list dmz_in extended permit icmp any any
access-list dmz_in extended permit udp 192.168.2.0 255.255.255.0 host 192.168.20.10 eq domain
access-list dmz_in extended deny ip 192.168.2.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list dmz_in extended permit ip any any
access-list dmz_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list dmz_access_in extended permit tcp any any
access-list Internal_nat0_outbound extended permit ip any 192.168.20.0 255.255.255.0
access-list Internal_nat0_outbound extended permit ip any any
access-list INTERNAL_access_out extended permit tcp any any
pager lines 24
logging enable
logging asdm informational
mtu INTERNAL 1500
mtu EXTERNAL 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (INTERNAL) 2 interface
global (EXTERNAL) 1 interface
global (DMZ) 3 interface
nat (INTERNAL) 1 0.0.0.0 0.0.0.0
nat (DMZ) 1 0.0.0.0 0.0.0.0
static (DMZ,INTERNAL) 192.168.20.10 192.168.2.1 netmask 255.255.255.255
static (INTERNAL,DMZ) 192.168.2.2 192.168.20.250 netmask 255.255.255.255
Thank you for all help in anticipation...
George
Re: ASA 5505 setup with DMZ (Exchange OWA)-outside(Netgea) - ins
Hello George...
first thing I noticed is that you don't have a translation rule for you internal users to reach the DMZ.
maybe
static (INTERNAL,DMZ) 192.168.20.0 192.168.20.0 netmask 255.255.255.0
I don't see a reason why you would translate your inside interface ip to the DMZ interface ip so I'd get rid of
With this you should at least be able to communicate from the inside to the dmz.
Thanks I will go ahead and change that...and let you know if I'm able to ping the DMZ.
Green
Is it your intention to only allow "tcp" outbound? If you need udp, change this to "ip".
access-list INTERNAL_access_out extended permit ip any any
I am first trying to ping all the networks and then I plan to setup the individual port access..but you are correct I should remove it. Having trouble pinging between 10.0.10.2(outside) and 192.168.20.250(inside), can you see any reason why this could be?
Green
You would need
access-list External_access_in extended permit icmp host 10.0.10.2 host 192.168.20.250
Still having trouble pinging between INTERNAL and DMZ.
Here's my config:
interface Vlan1
nameif INTERNAL
security-level 90
interface Vlan2
nameif EXTERNAL
security-level 0
interface Vlan12
nameif DMZ
security-level 90
ftp mode passive
domain-name xxx.int
access-list INTERNAL_access_in extended permit icmp any any
access-group INTERNAL_access_in in interface INTERNAL
access-group INTERNAL_access_out out interface INTERNAL
access-group External_access_in in interface EXTERNAL per-user-override
access-group dmz_in in interface DMZ per-user-override
route INTERNAL 0.0.0.0 0.0.0.0 192.168.20.250 1
route DMZ 0.0.0.0 0.0.0.0 192.168.2.2 2
I did make the suggested changes to the config to no avail:(
ASA is proving somewhat of a pain in the b&*!
George
Green
So can you ping from 10.0.10.2(outside) to 192.168.20.250(inside)?
When pinging from inside to dmz, what is the asa logging?
What is this for?
Nope, not able to ping from 10.0.10.2(outside) to 192.168.20.250(inside)....I will remove both:
George
Green
Sorry, I steered you in the wrong direction before. My mistake, should have read more closely.
I guess you're doing NAT/PAT on the netgear firewall? That 10. network is not routable on the internet so I suppose you are nat to public address on netgera? What do you want the outside address of your web/mail server to be? In your current acl you have it written as 10.0.10.1, which you say is your inside address of netgear fw? And you have no corresponding static for the web/mail servers. Lets start here and get you hitting dmz from inside.
no route DMZ 0.0.0.0 0.0.0.0 192.168.2.2 2
no route INTERNAL 0.0.0.0 0.0.0.0 192.168.20.250
route EXTERNAL 0.0.0.0 0.0.0.0 10.0.10.1
no global (DMZ) 3 interface
no nat (DMZ) 1 0.0.0.0 0.0.0.0
clear xlate
Yes, I am nat/pat through netgear to web/ftp i.e.
Internet|- Netgear -|- web/ftp -|- Internal
public IP | 10.0.10.1(netgear) | 10.0.10.2 and 192.168.2.1 (dmz) | 192.168.2.2 and 192.168.20.250(internal) and 10.0.10.2(external)
This may be alittle complicated-maybe there is a better way but I like having the netgear as added protection....
Let me know if this isn't clear, and I will try to clarify. My big concern right now is the inability to ping between the INTERNAL net and the DMZ net. Somehow the 192.168.20.250 ip can't ping the 192.168.2.2 ip. I guess somehow packets aren't being routed. I enter your changes and let you know how things are going...
Kind regards,
George.
Green
Honestly, I don't know how many people would say that adding a SOHO firewall in front of an enterprise firewall makes sense as far as extra protection. It most likely won't make the network any more reliable. This is only my opinion of course, if you want it that way, we'll make it work. But it will complicate the process.
Green
Next, lets deal with the web/ftp server. For arguments sake, lets say outside address of web/ftp server is 10.0.10.10 and inside dmz address is 192.168.2.10. You would need
static (INTERNAL,EXTERNAL) 10.0.10.10 192.168.2.10 netmask 255.255.255.255
access-list External_access_in extended permit tcp any host 10.0.10.10 eq ftp
access-list External_access_in extended permit tcp any host 10.0.10.10 eq www
access-group External_access_in in interface External
971
