Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA 5505 - Strange behavior on inside interface
I have an ASA5505 and the software Version is 7.2(4).
The problem is thet it stops passing traffic randomly, after a day or 1 hour or so on.
I can reach the ASA trough the outside interface using SSH but the inside interface is isolated.
The interfaces are up/up and there aren't errors.
I can't ping from the ASA to an inside host and vice versa.
The layer 2 seems to be working, if I clear the ASA's arp cache and then I try to ping, when I check the arp cache I've got a correct MAC address association.
What I get from ping command is "????" as an ACL is blocking it.
The only way to get it working again is to reboot.
Any help will be apreciated.
Many thanks.
Re: ASA 5505 - Strange behavior on inside interface
Can you post the syslog message from the time you try to ping?
THX
If the configuration has not changed and you do have telnet enabled for your address, then check out this Bug ID CSCse08133 against the version you are running.
Also, see if the workaround fixes your problem.
Arul
*Pls rate if it helps*
I am experiencing same behaviour but only on outside interface. It gets isolated (arp works) but ping does not.
I am running sw ver 8.0(2) on ASA 5505 ... does someone know if this bug is fixed ?
Emir
I upgraded the ASA software 4 days ago, now it's running version 8.0, and it's working yet.
Thank you very much for the help.
172
