Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 unresponsive remote management
Anyone else experience unresponsive / lockups with Cisco ASA 5505 remote management ?
I think it happens like this:
1) With ASDM (Java Web Start), add new crypto map (it could be anything, just happens to be what i added the last time this happened)
2) Click apply
3) ASDM hangs (at this point the Java client becomes entirely unresponsive)
4) ASDM.jnlp refuses to connect and eventually timeout dialog appears. However, VPN connections are still accepted.
5) After a few hours (over night), the ASA refuses all incoming traffic including VPN connections.
I presume, your Internet connection is stabile. Hence, what version of FW software and ASDM are you running on?
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
I know the ASA 5505 is up because Nmap tells me so but no open ports, i.e. "1 IP address (1 host up) scanned in .."
After reboot Nmap would return something like this:
Starting Nmap 5.00 ( http://nmap.org ) at 2012-08-23 10:16 CEST
Interesting ports:
Not shown: 998 filtered ports
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 15.69 seconds
Versions installed are as follows, where ASA 8.2 is the latest possible with 512 MB RAM. But perhaps ASDM can be upgraded while keeping ASA at 8.2 ?
ASA Version: 8.2(1)
ASDM Version: 6.2(1)
Firewall Mode: Routed
Total Flash: 128 MB
Device Type: ASA 5505
Total Memory: 512 MB
ciscoasa> show version
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 16 hours 9 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 20, DMZ Unrestricted
Inside Hosts                 : Unlimited
Failover                     : Active/Standby
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 25
Dual ISPs                    : Enabled
VLAN Trunk Ports             : 8
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has an ASA 5505 Security Plus license.
Re: ASA 5505 unresponsive remote management
Hi Bro
Your Cisco ASDM version 6.2(1) could be hit with Cisco Bug ID CSCtl42678 and CSCsr89144. Please click on the URLs below for the description of the 2 Cisco Bug IDs.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsr89144
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl42678
Your action plan here is to upgrade your Cisco ASA FW and ASDM version to version 8.2.4 (asa824-k8.bin) and version 6.4.2 (asdm-642.bin) respectively.
Upgrading FW software image will require about 15 minutes downtime (including Pre-UAT and Post UAT network/application verification), but the ASDM upgrade can be done on the fly. No downtime needed here. Let me know how this goes.
Thank you for your reply Ramraj.
I'll try what you suggest but why those perticular versions and not latest possible?
Hi Bro
Since your current software image version is version 8.2.1, the latest within its's train is version 8.2.5. After version 8.2.5, is version 8.3 and so on. To upgrade to version 8.3 or 8.4 (latest), this requires memory upgrade. In other words, this requires costs $$$$. I hate to propose suggestions that involves costs, unless it's deemed necessary. Furthermore, the CLI syntax in version 8.3 or 8.4 for object names and NATs are totally different compared to version 8.2.X and below. Trust me! it's a pain :-p
For your information, I hate version 8.2.5, as it's very buggy for many reasons. Hence, I suggested to you version 8.2.4 instead. By the way, the ASDM version 6.4.2 is the latest version, suitable for version 8.2.4.
Lastly, upgrading your software image version from version 8.2.1 to 8.2.4, has almost no adverse effects on your present configuration. So, no worries there. Let me know how it goes. Should everything go well, you owe me a beer, just kidding! :-)
1196
