asa 5505, v7.2 how can i block traffic?
hi, can i block the traffic between the same ports of the asa? for example, the asa 5505 has 8 ports, the ethernet port from 1 to 7, are for the inside vlan, and i want to know if i can filter traffic using an ACL between the ethernet port 1 and 2 for example...if it is, how can i do that?
the ethernet port 0 is for the outside interface.
thanks
Re: asa 5505, v7.2 how can i block traffic?
Just put an ACL on both interfaces to block the traffic.
But make sure you permit the rest :)
You can also assign them same security levels and don't permit same-security-traffic permit INTER interface.
Farrukh
By default, the same security level interfaces
cannot communicate with one another.
To allow communication between interfaces of the
same security level use the command
"same-security-traffic permit inter-interface"
You can also use ACL, something like this
access-list one2two permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
access-group one2two in interface inside
187
