ASA 5505 ver 8.4 DMZ to Outside not working
I have an ASA 5505 ver 8.4. The configuration is provided below. My INSIDE hosts are able to get to the internet via the Outside interface. The DHCP for my INSIDE hosts are handled by my L3 3560 switch. My DMZ hosts DHCP is handled by the ASA 5505. I've included packet-tracer results for both from the DMZ to the Outside address (DNS server) and a return packet tracer from the Outside interface to the DMZ host address. I see that the return is failing, however everything I have tried so far hasn't worked. Thank you in advance for any assistance.
***************************************8
ASA Version 8.4(4)
hostname mxfw
domain-name moxiefl.com
enable password (removed)
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
switchport trunk allowed vlan 20,22
switchport mode trunk
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 10.0.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan20
nameif dmz
security-level 50
ip address 172.26.20.1 255.255.255.0
interface Vlan22
nameif dmz2
security-level 50
ip address 172.26.22.1 255.255.255.0
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 208.67.222.222
name-server 208.67.220.220
same-security-traffic permit inter-interface
object network Generic_All_Network
subnet 0.0.0.0 0.0.0.0
object network INSIDE_Hosts
subnet 10.1.0.0 255.255.0.0
object network AnyConnect_Hosts
subnet 192.168.60.0 255.255.255.0
object network NETWORK_OBJ_192.168.60.0_26
subnet 192.168.60.0 255.255.255.192
object network DMZ_Network
subnet 172.26.20.0 255.255.255.0
object network DMZ2_Network
subnet 172.26.22.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu outside 1500
mtu dmz 1500
mtu dmz2 1500
ip local pool VPN_POOL 192.168.60.20-192.168.60.40 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic Generic_All_Network interface
nat (inside,outside) source static INSIDE_Hosts INSIDE_Hosts destination static AnyConnect_Hosts AnyConnect_Hosts route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.60.0_26 NETWORK_OBJ_192.168.60.0_26 no-proxy-arp route-lookup
nat (dmz,outside) source dynamic Generic_All_Network interface
nat (dmz2,outside) source dynamic Generic_All_Network interface
route inside 10.1.0.0 255.255.0.0 10.0.1.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
fqdn anyconnect.moxiefl.com
subject-name CN=AnyConnect.moxiefl.com
keypair AnyConnect
proxy-ldc-issuer
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate 439a4452
    3082026c 308201d5 a0030201 02020443 9a445230 0d06092a 864886f7 0d010105
    05003048 311f301d 06035504 03131641 6e79436f 6e6e6563 742e6d6f 78696566
    6c2e636f 6d312530 2306092a 864886f7 0d010902 1616616e 79636f6e 6e656374
    2e6d6f78 6965666c 2e636f6d 301e170d 31333039 32373037 32353331 5a170d32
    33303932 35303732 3533315a 3048311f 301d0603 55040313 16416e79 436f6e6e
    6563742e 6d6f7869 65666c2e 636f6d31 25302306 092a8648 86f70d01 09021616
    616e7963 6f6e6e65 63742e6d 6f786965 666c2e63 6f6d3081 9f300d06 092a8648
    86f70d01 01010500 03818d00 30818902 8181009a d9f320ff e93d4fdd cb707a4c
    b4664c47 6d2cc639 4dc45fed bfbc2150 7109fd81 5d6a5252 3d40dc43 696360d5
    fbf92bcc 477d19b8 5301085c daf40de5 87d7e4aa f81b8d7f 8d364dfa 0a6f07d7
    6a7c3e9b 56e69152 aa5492d8 e35537bd 567ccf29 7afbeae8 13da9936 9f890d76
    1d56d11d da3d039a 0e714849 e6841ff2 5483b102 03010001 a3633061 300f0603
    551d1301 01ff0405 30030101 ff300e06 03551d0f 0101ff04 04030201 86301f06
    03551d23 04183016 80142f27 7096c4c5 e396e691 e07ef737 af61b71f 64f1301d
    0603551d 0e041604 142f2770 96c4c5e3 96e691e0 7ef737af 61b71f64 f1300d06
    092a8648 86f70d01 01050500 03818100 8f777196 bbe6a5e4 8af9eb9a 514a8348
    5e62d6cd 47257243 e430a758 2b367543 065d4ceb 582bf666 08ff7be1 f89287a2
    ac527824 b11c2048 7fd2b50d 35ca3902 6aa00675 e4df7859 f3590596 b1d52426
    1e97a52c 4e77f4b0 226dec09 713f7ba9 80bdf7bb b52a7da2 4a68b91b 455cabba
    0cc4c6f3 f244f7d9 0a6e32fb 31ce7e35
  quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside client-services port 443
crypto ikev2 remote-access trustpoint ASDM_TrustPoint0
telnet timeout 5
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 208.67.222.222 208.67.220.220
dhcpd auto_config outside
dhcpd address 10.0.1.20-10.0.1.40 inside
dhcpd dns 208.67.222.222 208.67.220.220 interface inside
dhcpd enable inside
dhcpd address 172.26.20.21-172.26.20.60 dmz
dhcpd dns 208.67.222.222 208.67.220.220 interface dmz
dhcpd enable dmz
dhcpd address 172.26.22.21-172.26.22.200 dmz2
dhcpd dns 208.67.222.222 208.67.220.220 interface dmz2
dhcpd enable dmz2
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 outside
webvpn
enable outside
anyconnect-essentials
anyconnect image disk0:/anyconnect-win-3.0.2052-k9.pkg 1
anyconnect profiles AnyConnect_client_profile disk0:/AnyConnect_client_profile.xml
anyconnect enable
tunnel-group-list enable
group-policy GroupPolicy_AnyConnect internal
group-policy GroupPolicy_AnyConnect attributes
wins-server none
dns-server value 208.67.222.222 208.67.220.220
vpn-tunnel-protocol ikev2 ssl-client
default-domain value moxiefl.com
webvpn
  anyconnect profiles value AnyConnect_client_profile type user
username user1 password $$$$$$$$$$$$$$$$$ encrypted privilege 15
username user2 password $$$$$$$$$$$$$$$$$ encrypted privilege 15
tunnel-group AnyConnect type remote-access
tunnel-group AnyConnect general-attributes
address-pool VPN_POOL
default-group-policy GroupPolicy_AnyConnect
tunnel-group AnyConnect webvpn-attributes
group-alias AnyConnect enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:f2c7362097b71bcada023c6bbfc45121
: end
Packet Tracer from DMZ to Outside
mxfw# packet-tracer input dmz icmp 172.26.20.22 8 0 208.67.222.222 detailed
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Forward Flow based lookup yields rule:
in  id=0xac5bdb90, priority=0, domain=inspect-ip-options, deny=true
        hits=22, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
        input_ifc=dmz, output_ifc=any
Phase: 3
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xacff7ee0, priority=70, domain=inspect-icmp, deny=false
        hits=8, user_data=0xad253a68, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
        src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, dscp=0x0
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xac5bd768, priority=66, domain=inspect-icmp-error, deny=false
        hits=8, user_data=0xac5bcd80, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 172.26.20.22/0 to 192.168.1.231/23136
in  id=0xac63c0e8, priority=6, domain=nat, deny=false
        hits=7, user_data=0xac6209f0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        input_ifc=dmz, output_ifc=outside
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in  id=0xac578bf0, priority=0, domain=inspect-ip-options, deny=true
        hits=7510, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=outside, output_ifc=any
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 7561, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: dmz
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Packet Tracer for return from Outside:
mxfw(config)# packet-tracer input outside icmp 207.67.222.222 0 0 172.26.20.22$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.26.20.0     255.255.255.0   dmz
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xacea45d8, priority=11, domain=permit, deny=true
        hits=0, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: outside
input-status: up
output-interface: dmz
output-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Settings of PC and PING & tracert results
C:\Users>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : MXW8DT01
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 11:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 68-94-23-20-FA-C5
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Ralink RT5390R 802.11bgn Wi-Fi Adapter
   Physical Address. . . . . . . . . : 68-94-23-20-FA-C3
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
   Physical Address. . . . . . . . . : 08-9E-01-3D-64-39
   IPv4 Address. . . . . . . . . . . : 172.26.20.22(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sunday, October 6, 2013 3:28:48 PM
   Lease Expires . . . . . . . . . . : Sunday, October 6, 2013 4:28:48 PM
   Default Gateway . . . . . . . . . : 172.26.20.1
   DHCP Server . . . . . . . . . . . : 172.26.20.1
   DNS Servers . . . . . . . . . . . : 208.67.222.222
                                       208.67.220.220
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{9B004C7D-7A34-4A9C-BEDB-5212A582FAB1}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:3497:208a:53e5:ebe9(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::3497:208a:53e5:ebe9%16(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users>ping 208.67.222.222
Pinging 208.67.222.222 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 208.67.222.222:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users>tracert 208.67.222.222
Tracing route to 208.67.222.222 over a maximum of 30 hops
  1     1 ms    <1 ms    <1 ms  172.26.20.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
10     *        *        *     Request timed out.
11     *        *        *     Request timed out.
12     *        *        *     Request timed out.
13     *        *        *     Request timed out.
14     *        *        *     Request timed out.
15     *        *        *     Request timed out.
16     *        *        *     Request timed out.
17     *        *        *     Request timed out.
18     *        *        *     Request timed out.
19     *        *        *     Request timed out.
20     *        *        *     Request timed out.
21     *        *        *     Request timed out.
22     *        *        *     Request timed out.
23     *        *        *     Request timed out.
24     *        *        *     Request timed out.
25     *        *        *     Request timed out.
26     *        *        *     Request timed out.
27     *        *        *     Request timed out.
28     *        *        *     Request timed out.
29     *        *        *     Request timed out.
30     *        *        *     Request timed out.
Trace complete.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Sure,
I used 4.2.2.2 but you could use whatever you want.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hall of Fame Super Silver
Is your outside interface getting an RFC 1918 address? The packet trace from DMZ to outside indicates so:
So there must be upstream NAT to get to your intended address of 208.67.222.222. Is that configured correctly?
The packet tracer for outside to inside will of course fail as you don't allow public addresses to initiate communications in any of the access-lists your provided.
Marvin,
Yes there is an upstream NAT currently (I have the network at my house temporarily while the building it will be installed is being built - I am trying to get it operational to drop in place after the build).  I haven't made any changes to that router as of this time, however it is allowing my INSIDE traffic (10.0.1.0/24 and 10.1.10.0/24 networks) get to the DNS provider and the Internet.
Thank you for the quick response. I work nights so I won't be able to look at this until tomorrow morning.
Jerry
     The packet tracer from DMZ to Outside clearly shows that the packet is premitted on ASA for outbound.
Please apply captures on both DMZ and outside interfaces to verify if the packet is leaving the egress interface i.e outside interface or not.
You can apply captures as follows:
access-list capdmz permit icmp host 172.26.20.22 host 208.67.222.222
access-list capdmz permit icmp host 208.67.222.222 host 172.26.20.22
access-list capout permit icmp host 192.168.1.231 host 208.67.222.222
access-list capout permit icmp host 208.67.222.222 host 192.168.1.231
cap capd interface dmz access-list capdmz
cap capo interface outside access-list capout.
check if you see traffic leaving firewall in capo by "show capo"
Once verified, you can check further on the ISP end device for correct setting for NAT.
Cheers,
Naveen
Naveen,
The results from the "sho cap capo" are below.
As they show the ping is leaving the ASA and the reply is coming back to the ASA (so the additional NAT is not stopping the PING, the ASA is not routing the Echo Reply back to the DMZ).  As stated earlier PINGs and Internet access from my INSIDE network are working just not from the DMZ.  Based on the packet-tracer I could determine that the ASA is not routing the PINGs back to the DMZ, I just can't determine why.
Thank you for your assistance.
Jerry
mxfw# sho cap capo
8 packets captured
   1: 08:49:55.933347 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   2: 08:49:55.961345 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   3: 08:50:00.697122 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   4: 08:50:00.723915 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   5: 08:50:05.696283 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   6: 08:50:05.721947 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   7: 08:50:10.695474 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   8: 08:50:10.722466 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
8 packets shown
Great,
Some progress here, so we are getting the packets back to the firewall; however the packet is not reaching the destination.
Can you set the same captures and add one more to them and get the outputs.
New capture:
cap asp type asp-drop all
NOs gather the output of following:
sh cap asp
sh cap capo
sh cap capdmz
This would help us to determine that either the packet is dropped by the firewall or the reply is leaving or not through dmz interface.
Cheers,
Naveen
Naveen & Julio,
The version is below along with the captures.  The show cap asp | include 208.67.222.222 is fairly long.
Thank you again for your assistance.
Jerry
mxfw(config)# sho ver
Cisco Adaptive Security Appliance Software Version 8.4(4)
Device Manager Version 6.4(9)
Compiled on Mon 21-May-12 10:48 by builders
System image file is "disk0:/asa844-k8.bin"
Config file at boot was "startup-config"
mxfw up 23 hours 47 mins
Hardware:   ASA5505, 1024 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 32768MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.06
                             Number of accelerators: 1
0: Int: Internal-Data0/0    : address is 2c54.2df4.9c93, irq 11
1: Ext: Ethernet0/0         : address is 2c54.2df4.9c8b, irq 255
2: Ext: Ethernet0/1         : address is 2c54.2df4.9c8c, irq 255
3: Ext: Ethernet0/2         : address is 2c54.2df4.9c8d, irq 255
4: Ext: Ethernet0/3         : address is 2c54.2df4.9c8e, irq 255
5: Ext: Ethernet0/4         : address is 2c54.2df4.9c8f, irq 255
6: Ext: Ethernet0/5         : address is 2c54.2df4.9c90, irq 255
7: Ext: Ethernet0/6         : address is 2c54.2df4.9c91, irq 255
8: Ext: Ethernet0/7         : address is 2c54.2df4.9c92, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             : 20             DMZ Unrestricted
Dual ISPs                         : Enabled        perpetual
VLAN Trunk Ports                  : 8              perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Standby perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
AnyConnect Premium Peers          : 25             perpetual
AnyConnect Essentials             : 25             perpetual
Other VPN Peers                   : 25             perpetual
Total VPN Peers                   : 25             perpetual
Shared License                    : Enabled        perpetual
AnyConnect for Mobile             : Enabled        perpetual
AnyConnect for Cisco VPN Phone    : Enabled        perpetual
Advanced Endpoint Assessment      : Enabled        perpetual
UC Phone Proxy Sessions           : 24             perpetual
Total UC Proxy Sessions           : 24             perpetual
Botnet Traffic Filter             : Enabled        perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has an ASA 5505 Security Plus license.
Serial Number: JMX1617Z2B0
Running Permanent Activation Key: 0x112dd960 0x68ba556a 0x9160b8f4 0xc4f49064 0x822ae087
Configuration register is 0x1
mxfw(config)# sho cap asp | include 208.67.222.222
   1: 08:14:03.444953 802.1Q vlan#2 P0 192.168.60.20.50815 > 208.67.222.222.53:  udp 38
   4: 08:14:04.613920 802.1Q vlan#2 P0 192.168.60.20.49379 > 208.67.222.222.53:  udp 36 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
   9: 08:14:05.456168 802.1Q vlan#2 P0 192.168.60.20.50815 > 208.67.222.222.53:  udp 38 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  19: 08:14:07.874283 802.1Q vlan#2 P0 192.168.60.20.52778 > 208.67.222.222.53:  udp 39 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  26: 08:14:09.464407 802.1Q vlan#2 P0 192.168.60.20.50815 > 208.67.222.222.53:  udp 38 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  31: 08:14:09.885559 802.1Q vlan#2 P0 192.168.60.20.52778 > 208.67.222.222.53:  udp 39 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  36: 08:14:11.228427 802.1Q vlan#2 P0 192.168.60.20.57817 > 208.67.222.222.53:  udp 36
  37: 08:14:12.240847 802.1Q vlan#2 P0 192.168.60.20.57817 > 208.67.222.222.53:  udp 36 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  38: 08:14:13.254533 802.1Q vlan#2 P0 192.168.60.20.57817 > 208.67.222.222.53:  udp 36 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  44: 08:14:13.893889 802.1Q vlan#2 P0 192.168.60.20.52778 > 208.67.222.222.53:  udp 39 Drop-reason: (unable-to-create-flow) Flow denied due to resource limitation
  51: 08:14:15.266374 802.1Q vlan#2 P0 192.168.60.20.57817 > 208.67.222.222.53:  udp 36
  63: 08:14:19.274750 802.1Q vlan#2 P0 192.168.60.20.57817 > 208.67.222.222.53:  udp 36
  68: 08:14:20.509312 802.1Q vlan#2 P0 192.168.60.20.50543 > 208.67.222.222.53:  udp 39
  69: 08:14:21.520816 802.1Q vlan#2 P0 192.168.60.20.50543 > 208.67.222.222.53:  udp 39
  70: 08:14:22.534548 802.1Q vlan#2 P0 192.168.60.20.50543 > 208.67.222.222.53:  udp 39
  76: 08:14:24.547228 802.1Q vlan#2 P0 192.168.60.20.50543 > 208.67.222.222.53:  udp 39
  83: 08:14:28.554826 802.1Q vlan#2 P0 192.168.60.20.50543 > 208.67.222.222.53:  udp 39
  89: 08:14:29.803150 802.1Q vlan#2 P0 192.168.60.20.54948 > 208.67.222.222.53:  udp 38
  91: 08:14:31.816089 802.1Q vlan#2 P0 192.168.60.20.54948 > 208.67.222.222.53:  udp 38
102: 08:14:35.822894 802.1Q vlan#2 P0 192.168.60.20.54948 > 208.67.222.222.53:  udp 38
116: 08:14:42.885604 802.1Q vlan#2 P0 192.168.60.20.62505 > 208.67.222.222.53:  udp 34
118: 08:14:43.883926 802.1Q vlan#2 P0 192.168.60.20.62505 > 208.67.222.222.53:  udp 34
123: 08:14:44.884491 802.1Q vlan#2 P0 192.168.60.20.62505 > 208.67.222.222.53:  udp 34
127: 08:14:46.884521 802.1Q vlan#2 P0 192.168.60.20.62505 > 208.67.222.222.53:  udp 34
133: 08:14:48.882721 802.1Q vlan#2 P0 192.168.60.20.52421 > 208.67.222.222.53:  udp 34
135: 08:14:49.881942 802.1Q vlan#2 P0 192.168.60.20.52421 > 208.67.222.222.53:  udp 34
138: 08:14:50.882858 802.1Q vlan#2 P0 192.168.60.20.52421 > 208.67.222.222.53:  udp 34
140: 08:14:50.885620 802.1Q vlan#2 P0 192.168.60.20.62505 > 208.67.222.222.53:  udp 34
145: 08:14:52.883590 802.1Q vlan#2 P0 192.168.60.20.52421 > 208.67.222.222.53:  udp 34
149: 08:14:53.983790 802.1Q vlan#2 P0 192.168.60.20.56343 > 208.67.222.222.53:  udp 38
151: 08:14:54.982981 802.1Q vlan#2 P0 192.168.60.20.56343 > 208.67.222.222.53:  udp 38
156: 08:14:55.982844 802.1Q vlan#2 P0 192.168.60.20.56343 > 208.67.222.222.53:  udp 38
161: 08:14:56.884811 802.1Q vlan#2 P0 192.168.60.20.52421 > 208.67.222.222.53:  udp 34
180: 08:14:57.983408 802.1Q vlan#2 P0 192.168.60.20.56343 > 208.67.222.222.53:  udp 38
197: 08:14:59.441017 802.1Q vlan#2 P0 192.168.60.20.55495 > 208.67.222.222.53:  udp 34
198: 08:14:59.441764 802.1Q vlan#2 P0 192.168.60.20.52091 > 208.67.222.222.53:  udp 42
199: 08:14:59.442756 802.1Q vlan#2 P0 192.168.60.20.52233 > 208.67.222.222.53:  udp 40
200: 08:14:59.442985 802.1Q vlan#2 P0 192.168.60.20.57413 > 208.67.222.222.53:  udp 40
201: 08:14:59.443794 802.1Q vlan#2 P0 192.168.60.20.65042 > 208.67.222.222.53:  udp 40
202: 08:14:59.448753 802.1Q vlan#2 P0 192.168.60.20.62151 > 208.67.222.222.53:  udp 34
204: 08:14:59.504978 802.1Q vlan#2 P0 192.168.60.20.60528 > 208.67.222.222.53:  udp 33
206: 08:14:59.524234 802.1Q vlan#2 P0 192.168.60.20.54032 > 208.67.222.222.53:  udp 34
213: 08:15:00.505161 802.1Q vlan#2 P0 192.168.60.20.60528 > 208.67.222.222.53:  udp 33
214: 08:15:00.524066 802.1Q vlan#2 P0 192.168.60.20.54032 > 208.67.222.222.53:  udp 34
225: 08:15:01.441124 802.1Q vlan#2 P0 192.168.60.20.55495 > 208.67.222.222.53:  udp 34
229: 08:15:01.442893 802.1Q vlan#2 P0 192.168.60.20.57413 > 208.67.222.222.53:  udp 40
230: 08:15:01.443168 802.1Q vlan#2 P0 192.168.60.20.52233 > 208.67.222.222.53:  udp 40
235: 08:15:01.444663 802.1Q vlan#2 P0 192.168.60.20.65042 > 208.67.222.222.53:  udp 40
241: 08:15:01.563584 802.1Q vlan#2 P0 192.168.60.20.49326 > 208.67.222.222.53:  udp 32
242: 08:15:01.582458 802.1Q vlan#2 P0 192.168.60.20.64011 > 208.67.222.222.53:  udp 33
244: 08:15:01.598983 802.1Q vlan#2 P0 192.168.60.20.55971 > 208.67.222.222.53:  udp 33
246: 08:15:01.628278 802.1Q vlan#2 P0 192.168.60.20.54709 > 208.67.222.222.53:  udp 37
248: 08:15:01.982920 802.1Q vlan#2 P0 192.168.60.20.56343 > 208.67.222.222.53:  udp 38
254: 08:15:02.598861 802.1Q vlan#2 P0 192.168.60.20.55971 > 208.67.222.222.53:  udp 33
256: 08:15:02.622785 802.1Q vlan#2 P0 192.168.60.20.54709 > 208.67.222.222.53:  udp 37
266: 08:15:04.438301 802.1Q vlan#2 P0 192.168.60.20.57642 > 208.67.222.222.53:  udp 34
267: 08:15:04.440040 802.1Q vlan#2 P0 192.168.60.20.49886 > 208.67.222.222.53:  udp 40
268: 08:15:04.440284 802.1Q vlan#2 P0 192.168.60.20.64655 > 208.67.222.222.53:  udp 40
269: 08:15:04.441078 802.1Q vlan#2 P0 192.168.60.20.57383 > 208.67.222.222.53:  udp 40
279: 08:15:05.441551 802.1Q vlan#2 P0 192.168.60.20.55495 > 208.67.222.222.53:  udp 34
285: 08:15:05.443168 802.1Q vlan#2 P0 192.168.60.20.52233 > 208.67.222.222.53:  udp 40
286: 08:15:05.443443 802.1Q vlan#2 P0 192.168.60.20.57413 > 208.67.222.222.53:  udp 40
293: 08:15:05.445396 802.1Q vlan#2 P0 192.168.60.20.65042 > 208.67.222.222.53:  udp 40
314: 08:15:07.438911 802.1Q vlan#2 P0 192.168.60.20.57642 > 208.67.222.222.53:  udp 34
318: 08:15:07.440040 802.1Q vlan#2 P0 192.168.60.20.49886 > 208.67.222.222.53:  udp 40
322: 08:15:07.441322 802.1Q vlan#2 P0 192.168.60.20.64655 > 208.67.222.222.53:  udp 40
326: 08:15:07.443412 802.1Q vlan#2 P0 192.168.60.20.57383 > 208.67.222.222.53:  udp 40
335: 08:15:09.374400 802.1Q vlan#2 P0 192.168.60.20.59105 > 208.67.222.222.53:  udp 38
362: 08:15:11.439399 802.1Q vlan#2 P0 192.168.60.20.57642 > 208.67.222.222.53:  udp 34
363: 08:15:11.440101 802.1Q vlan#2 P0 192.168.60.20.49886 > 208.67.222.222.53:  udp 40
370: 08:15:11.441627 802.1Q vlan#2 P0 192.168.60.20.64655 > 208.67.222.222.53:  udp 40
374: 08:15:11.442543 802.1Q vlan#2 P0 192.168.60.20.57383 > 208.67.222.222.53:  udp 40
381: 08:15:11.995279 802.1Q vlan#2 P0 192.168.60.20.58440 > 208.67.222.222.53:  udp 34
382: 08:15:12.003127 802.1Q vlan#2 P0 192.168.60.20.63442 > 208.67.222.222.53:  udp 40
383: 08:15:12.003356 802.1Q vlan#2 P0 192.168.60.20.65017 > 208.67.222.222.53:  udp 40
384: 08:15:12.003585 802.1Q vlan#2 P0 192.168.60.20.62373 > 208.67.222.222.53:  udp 40
387: 08:15:12.994989 802.1Q vlan#2 P0 192.168.60.20.58440 > 208.67.222.222.53:  udp 34
388: 08:15:13.001922 802.1Q vlan#2 P0 192.168.60.20.63442 > 208.67.222.222.53:  udp 40
389: 08:15:13.004455 802.1Q vlan#2 P0 192.168.60.20.65017 > 208.67.222.222.53:  udp 40
390: 08:15:13.004974 802.1Q vlan#2 P0 192.168.60.20.62373 > 208.67.222.222.53:  udp 40
391: 08:15:13.005660 802.1Q vlan#2 P0 192.168.60.20.59092 > 208.67.222.222.53:  udp 33
392: 08:15:13.995065 802.1Q vlan#2 P0 192.168.60.20.58440 > 208.67.222.222.53:  udp 34
394: 08:15:14.001922 802.1Q vlan#2 P0 192.168.60.20.63442 > 208.67.222.222.53:  udp 40
396: 08:15:14.002868 802.1Q vlan#2 P0 192.168.60.20.62373 > 208.67.222.222.53:  udp 40
397: 08:15:14.003082 802.1Q vlan#2 P0 192.168.60.20.65017 > 208.67.222.222.53:  udp 40
400: 08:15:14.004104 802.1Q vlan#2 P0 192.168.60.20.59092 > 208.67.222.222.53:  udp 33
418: 08:15:15.995416 802.1Q vlan#2 P0 192.168.60.20.58440 > 208.67.222.222.53:  udp 34
422: 08:15:16.002334 802.1Q vlan#2 P0 192.168.60.20.63442 > 208.67.222.222.53:  udp 40
426: 08:15:16.003570 802.1Q vlan#2 P0 192.168.60.20.62373 > 208.67.222.222.53:  udp 40
427: 08:15:16.003738 802.1Q vlan#2 P0 192.168.60.20.65017 > 208.67.222.222.53:  udp 40
446: 08:15:17.302062 802.1Q vlan#2 P0 192.168.60.20.63130 > 208.67.222.222.53:  udp 34
451: 08:15:18.172003 802.1Q vlan#2 P0 192.168.60.20.63438 > 208.67.222.222.53:  udp 39
466: 08:15:18.993829 802.1Q vlan#2 P0 192.168.60.20.62143 > 208.67.222.222.53:  udp 34
467: 08:15:19.000717 802.1Q vlan#2 P0 192.168.60.20.62168 > 208.67.222.222.53:  udp 40
468: 08:15:19.000945 802.1Q vlan#2 P0 192.168.60.20.53798 > 208.67.222.222.53:  udp 40
469: 08:15:19.002670 802.1Q vlan#2 P0 192.168.60.20.49384 > 208.67.222.222.53:  udp 40
474: 08:15:19.695703 802.1Q vlan#2 P0 192.168.60.20.60662 > 208.67.222.222.53:  udp 45
478: 08:15:19.994882 802.1Q vlan#2 P0 192.168.60.20.58440 > 208.67.222.222.53:  udp 34
486: 08:15:20.002120 802.1Q vlan#2 P0 192.168.60.20.63442 > 208.67.222.222.53:  udp 40
490: 08:15:20.003066 802.1Q vlan#2 P0 192.168.60.20.62373 > 208.67.222.222.53:  udp 40
492: 08:15:20.003539 802.1Q vlan#2 P0 192.168.60.20.65017 > 208.67.222.222.53:  udp 40
500: 08:15:20.303008 802.1Q vlan#2 P0 192.168.60.20.63130 > 208.67.222.222.53:  udp 34
504: 08:15:20.411660 802.1Q vlan#2 P0 192.168.60.20.55911 > 208.67.222.222.53:  udp 38
510: 08:15:20.984369 802.1Q vlan#2 P0 192.168.60.20.50215 > 208.67.222.222.53:  udp 38
511: 08:15:21.171850 802.1Q vlan#2 P0 192.168.60.20.63438 > 208.67.222.222.53:  udp 39
525: 08:15:21.983744 802.1Q vlan#2 P0 192.168.60.20.50215 > 208.67.222.222.53:  udp 38
526: 08:15:21.993555 802.1Q vlan#2 P0 192.168.60.20.62143 > 208.67.222.222.53:  udp 34
530: 08:15:22.000366 802.1Q vlan#2 P0 192.168.60.20.54586 > 208.67.222.222.53:  udp 34
531: 08:15:22.001602 802.1Q vlan#2 P0 192.168.60.20.62168 > 208.67.222.222.53:  udp 40
532: 08:15:22.001846 802.1Q vlan#2 P0 192.168.60.20.53798 > 208.67.222.222.53:  udp 40
539: 08:15:22.004150 802.1Q vlan#2 P0 192.168.60.20.49384 > 208.67.222.222.53:  udp 40
547: 08:15:22.986216 802.1Q vlan#2 P0 192.168.60.20.50215 > 208.67.222.222.53:  udp 38
549: 08:15:22.999444 802.1Q vlan#2 P0 192.168.60.20.54586 > 208.67.222.222.53:  udp 34
565: 08:15:23.999170 802.1Q vlan#2 P0 192.168.60.20.54586 > 208.67.222.222.53:  udp 34
576: 08:15:24.303252 802.1Q vlan#2 P0 192.168.60.20.63130 > 208.67.222.222.53:  udp 34
584: 08:15:24.985254 802.1Q vlan#2 P0 192.168.60.20.50215 > 208.67.222.222.53:  udp 38
592: 08:15:25.172186 802.1Q vlan#2 P0 192.168.60.20.63438 > 208.67.222.222.53:  udp 39
604: 08:15:25.994012 802.1Q vlan#2 P0 192.168.60.20.62143 > 208.67.222.222.53:  udp 34
608: 08:15:25.998926 802.1Q vlan#2 P0 192.168.60.20.54586 > 208.67.222.222.53:  udp 34
610: 08:15:26.001953 802.1Q vlan#2 P0 192.168.60.20.62168 > 208.67.222.222.53:  udp 40
611: 08:15:26.002441 802.1Q vlan#2 P0 192.168.60.20.53798 > 208.67.222.222.53:  udp 40
618: 08:15:26.004226 802.1Q vlan#2 P0 192.168.60.20.49384 > 208.67.222.222.53:  udp 40
643: 08:15:28.986582 802.1Q vlan#2 P0 192.168.60.20.50215 > 208.67.222.222.53:  udp 38
657: 08:15:29.999307 802.1Q vlan#2 P0 192.168.60.20.54586 > 208.67.222.222.53:  udp 34
681: 08:15:31.458914 802.1Q vlan#2 P0 192.168.60.20.63467 > 208.67.222.222.53:  udp 37
685: 08:15:31.724190 802.1Q vlan#2 P0 192.168.60.20.53683 > 208.67.222.222.53:  udp 39
691: 08:15:31.875671 802.1Q vlan#2 P0 192.168.60.20.54302 > 208.67.222.222.53:  udp 37
700: 08:15:32.723961 802.1Q vlan#2 P0 192.168.60.20.53683 > 208.67.222.222.53:  udp 39
706: 08:15:33.724877 802.1Q vlan#2 P0 192.168.60.20.53683 > 208.67.222.222.53:  udp 39
712: 08:15:35.725670 802.1Q vlan#2 P0 192.168.60.20.53683 > 208.67.222.222.53:  udp 39
724: 08:15:39.726814 802.1Q vlan#2 P0 192.168.60.20.53683 > 208.67.222.222.53:  udp 39
732: 08:15:41.453269 802.1Q vlan#2 P0 192.168.60.20.64218 > 208.67.222.222.53:  udp 34
754: 08:15:43.453315 802.1Q vlan#2 P0 192.168.60.20.64218 > 208.67.222.222.53:  udp 34
764: 08:15:43.995737 802.1Q vlan#2 P0 192.168.60.20.53749 > 208.67.222.222.53:  udp 34
786: 08:15:45.994760 802.1Q vlan#2 P0 192.168.60.20.53749 > 208.67.222.222.53:  udp 34
795: 08:15:47.451194 802.1Q vlan#2 P0 192.168.60.20.64429 > 208.67.222.222.53:  udp 34
797: 08:15:47.454276 802.1Q vlan#2 P0 192.168.60.20.64218 > 208.67.222.222.53:  udp 34
806: 08:15:48.285110 802.1Q vlan#2 P0 192.168.60.20.55170 > 208.67.222.222.53:  udp 39
821: 08:15:49.451209 802.1Q vlan#2 P0 192.168.60.20.64429 > 208.67.222.222.53:  udp 34
826: 08:15:49.979868 802.1Q vlan#2 P0 192.168.60.20.53423 > 208.67.222.222.53:  udp 38
828: 08:15:49.994058 802.1Q vlan#2 P0 192.168.60.20.53749 > 208.67.222.222.53:  udp 34
830: 08:15:50.285217 802.1Q vlan#2 P0 192.168.60.20.55170 > 208.67.222.222.53:  udp 39
845: 08:15:51.979777 802.1Q vlan#2 P0 192.168.60.20.53423 > 208.67.222.222.53:  udp 38
856: 08:15:53.450660 802.1Q vlan#2 P0 192.168.60.20.64429 > 208.67.222.222.53:  udp 34
864: 08:15:54.008330 802.1Q vlan#2 P0 192.168.60.20.58160 > 208.67.222.222.53:  udp 34
865: 08:15:54.285507 802.1Q vlan#2 P0 192.168.60.20.55170 > 208.67.222.222.53:  udp 39
872: 08:15:55.008437 802.1Q vlan#2 P0 192.168.60.20.58160 > 208.67.222.222.53:  udp 34
876: 08:15:55.980250 802.1Q vlan#2 P0 192.168.60.20.53423 > 208.67.222.222.53:  udp 38
880: 08:15:56.009185 802.1Q vlan#2 P0 192.168.60.20.58160 > 208.67.222.222.53:  udp 34
886: 08:15:58.009902 802.1Q vlan#2 P0 192.168.60.20.58160 > 208.67.222.222.53:  udp 34
902: 08:16:00.006957 802.1Q vlan#2 P0 192.168.60.20.58798 > 208.67.222.222.53:  udp 34
908: 08:16:00.837679 802.1Q vlan#2 P0 192.168.60.20.58163 > 208.67.222.222.53:  udp 39
910: 08:16:01.006377 802.1Q vlan#2 P0 192.168.60.20.58798 > 208.67.222.222.53:  udp 34
914: 08:16:01.837221 802.1Q vlan#2 P0 192.168.60.20.58163 > 208.67.222.222.53:  udp 39
915: 08:16:01.991724 802.1Q vlan#2 P0 192.168.60.20.55645 > 208.67.222.222.53:  udp 34
916: 08:16:02.007217 802.1Q vlan#2 P0 192.168.60.20.58798 > 208.67.222.222.53:  udp 34
918: 08:16:02.010161 802.1Q vlan#2 P0 192.168.60.20.58160 > 208.67.222.222.53:  udp 34
923: 08:16:02.838182 802.1Q vlan#2 P0 192.168.60.20.58163 > 208.67.222.222.53:  udp 39
925: 08:16:02.991007 802.1Q vlan#2 P0 192.168.60.20.55645 > 208.67.222.222.53:  udp 34
931: 08:16:03.990885 802.1Q vlan#2 P0 192.168.60.20.55645 > 208.67.222.222.53:  udp 34
932: 08:16:04.007842 802.1Q vlan#2 P0 192.168.60.20.58798 > 208.67.222.222.53:  udp 34
938: 08:16:04.838823 802.1Q vlan#2 P0 192.168.60.20.58163 > 208.67.222.222.53:  udp 39
945: 08:16:05.990610 802.1Q vlan#2 P0 192.168.60.20.55645 > 208.67.222.222.53:  udp 34
957: 08:16:08.009215 802.1Q vlan#2 P0 192.168.60.20.58798 > 208.67.222.222.53:  udp 34
964: 08:16:08.840425 802.1Q vlan#2 P0 192.168.60.20.58163 > 208.67.222.222.53:  udp 39
970: 08:16:09.991052 802.1Q vlan#2 P0 192.168.60.20.55645 > 208.67.222.222.53:  udp 34
1005: 08:16:16.981287 802.1Q vlan#2 P0 192.168.60.20.53038 > 208.67.222.222.53:  udp 38
1008: 08:16:17.391352 802.1Q vlan#2 P0 192.168.60.20.49778 > 208.67.222.222.53:  udp 39
1010: 08:16:18.981348 802.1Q vlan#2 P0 192.168.60.20.53038 > 208.67.222.222.53:  udp 38
1015: 08:16:19.391428 802.1Q vlan#2 P0 192.168.60.20.49778 > 208.67.222.222.53:  udp 39
1022: 08:16:22.982645 802.1Q vlan#2 P0 192.168.60.20.53038 > 208.67.222.222.53:  udp 38
1027: 08:16:23.403650 802.1Q vlan#2 P0 192.168.60.20.49778 > 208.67.222.222.53:  udp 39
1032: 08:16:24.014434 802.1Q vlan#2 P0 192.168.60.20.54274 > 208.67.222.222.53:  udp 34
1059: 08:16:26.014113 802.1Q vlan#2 P0 192.168.60.20.54274 > 208.67.222.222.53:  udp 34
1096: 08:16:29.956737 802.1Q vlan#2 P0 192.168.60.20.61328 > 208.67.222.222.53:  udp 39
1097: 08:16:30.013381 802.1Q vlan#2 P0 192.168.60.20.54274 > 208.67.222.222.53:  udp 34
1099: 08:16:30.939343 802.1Q vlan#2 P0 192.168.60.20.58681 > 208.67.222.222.53:  udp 40
1100: 08:16:30.939572 802.1Q vlan#2 P0 192.168.60.20.51180 > 208.67.222.222.53:  udp 40
1101: 08:16:30.939801 802.1Q vlan#2 P0 192.168.60.20.53388 > 208.67.222.222.53:  udp 40
1102: 08:16:30.956081 802.1Q vlan#2 P0 192.168.60.20.61328 > 208.67.222.222.53:  udp 39
1106: 08:16:31.938870 802.1Q vlan#2 P0 192.168.60.20.58681 > 208.67.222.222.53:  udp 40
1107: 08:16:31.939099 802.1Q vlan#2 P0 192.168.60.20.51180 > 208.67.222.222.53:  udp 40
1108: 08:16:31.939785 802.1Q vlan#2 P0 192.168.60.20.53388 > 208.67.222.222.53:  udp 40
1109: 08:16:31.956890 802.1Q vlan#2 P0 192.168.60.20.61328 > 208.67.222.222.53:  udp 39
1112: 08:16:32.938916 802.1Q vlan#2 P0 192.168.60.20.51180 > 208.67.222.222.53:  udp 40
1113: 08:16:32.939145 802.1Q vlan#2 P0 192.168.60.20.58681 > 208.67.222.222.53:  udp 40
1116: 08:16:32.940075 802.1Q vlan#2 P0 192.168.60.20.53388 > 208.67.222.222.53:  udp 40
1140: 08:16:33.956401 802.1Q vlan#2 P0 192.168.60.20.61328 > 208.67.222.222.53:  udp 39
1148: 08:16:34.939740 802.1Q vlan#2 P0 192.168.60.20.58681 > 208.67.222.222.53:  udp 40
1149: 08:16:34.939999 802.1Q vlan#2 P0 192.168.60.20.51180 > 208.67.222.222.53:  udp 40
1150: 08:16:34.940228 802.1Q vlan#2 P0 192.168.60.20.53388 > 208.67.222.222.53:  udp 40
1161: 08:16:36.936810 802.1Q vlan#2 P0 192.168.60.20.59595 > 208.67.222.222.53:  udp 40
1162: 08:16:36.937970 802.1Q vlan#2 P0 192.168.60.20.59578 > 208.67.222.222.53:  udp 40
1163: 08:16:36.938244 802.1Q vlan#2 P0 192.168.60.20.64549 > 208.67.222.222.53:  udp 40
1168: 08:16:37.936002 802.1Q vlan#2 P0 192.168.60.20.59595 > 208.67.222.222.53:  udp 40
1169: 08:16:37.936948 802.1Q vlan#2 P0 192.168.60.20.59578 > 208.67.222.222.53:  udp 40
1170: 08:16:37.938046 802.1Q vlan#2 P0 192.168.60.20.64549 > 208.67.222.222.53:  udp 40
1171: 08:16:37.955883 802.1Q vlan#2 P0 192.168.60.20.61328 > 208.67.222.222.53:  udp 39
1175: 08:16:38.936948 802.1Q vlan#2 P0 192.168.60.20.59595 > 208.67.222.222.53:  udp 40
1177: 08:16:38.937817 802.1Q vlan#2 P0 192.168.60.20.59578 > 208.67.222.222.53:  udp 40
1179: 08:16:38.938763 802.1Q vlan#2 P0 192.168.60.20.64549 > 208.67.222.222.53:  udp 40
1181: 08:16:38.939709 802.1Q vlan#2 P0 192.168.60.20.58681 > 208.67.222.222.53:  udp 40
1185: 08:16:38.941006 802.1Q vlan#2 P0 192.168.60.20.51180 > 208.67.222.222.53:  udp 40
1186: 08:16:38.941220 802.1Q vlan#2 P0 192.168.60.20.53388 > 208.67.222.222.53:  udp 40
1195: 08:16:40.937512 802.1Q vlan#2 P0 192.168.60.20.59578 > 208.67.222.222.53:  udp 40
1196: 08:16:40.937741 802.1Q vlan#2 P0 192.168.60.20.59595 > 208.67.222.222.53:  udp 40
1199: 08:16:40.939602 802.1Q vlan#2 P0 192.168.60.20.64549 > 208.67.222.222.53:  udp 40
1208: 08:16:42.005874 802.1Q vlan#2 P0 192.168.60.20.61007 > 208.67.222.222.53:  udp 38
1216: 08:16:43.005202 802.1Q vlan#2 P0 192.168.60.20.61007 > 208.67.222.222.53:  udp 38
1229: 08:16:44.006026 802.1Q vlan#2 P0 192.168.60.20.61007 > 208.67.222.222.53:  udp 38
1237: 08:16:44.939419 802.1Q vlan#2 P0 192.168.60.20.59595 > 208.67.222.222.53:  udp 40
1238: 08:16:44.939908 802.1Q vlan#2 P0 192.168.60.20.59578 > 208.67.222.222.53:  udp 40
1245: 08:16:44.941494 802.1Q vlan#2 P0 192.168.60.20.64549 > 208.67.222.222.53:  udp 40
1275: 08:16:46.006011 802.1Q vlan#2 P0 192.168.60.20.61007 > 208.67.222.222.53:  udp 38
1321: 08:16:50.007079 802.1Q vlan#2 P0 192.168.60.20.61007 > 208.67.222.222.53:  udp 38
1398: 08:17:10.994073 802.1Q vlan#2 P0 192.168.60.20.63745 > 208.67.222.222.53:  udp 38
1401: 08:17:12.992517 802.1Q vlan#2 P0 192.168.60.20.63745 > 208.67.222.222.53:  udp 38
1426: 08:17:15.766638 802.1Q vlan#2 P0 192.168.60.20.64128 > 208.67.222.222.53:  udp 39
1429: 08:17:16.992761 802.1Q vlan#2 P0 192.168.60.20.63745 > 208.67.222.222.53:  udp 38
1433: 08:17:17.766729 802.1Q vlan#2 P0 192.168.60.20.64128 > 208.67.222.222.53:  udp 39
1441: 08:17:21.767050 802.1Q vlan#2 P0 192.168.60.20.64128 > 208.67.222.222.53:  udp 39
1452: 08:17:26.504170 802.1Q vlan#2 P0 192.168.60.20.51346 > 208.67.222.222.53:  udp 39
1463: 08:17:27.504032 802.1Q vlan#2 P0 192.168.60.20.51346 > 208.67.222.222.53:  udp 39
1465: 08:17:28.318953 802.1Q vlan#2 P0 192.168.60.20.49753 > 208.67.222.222.53:  udp 39
1466: 08:17:28.504887 802.1Q vlan#2 P0 192.168.60.20.51346 > 208.67.222.222.53:  udp 39
1468: 08:17:29.319212 802.1Q vlan#2 P0 192.168.60.20.49753 > 208.67.222.222.53:  udp 39
1475: 08:17:30.319746 802.1Q vlan#2 P0 192.168.60.20.49753 > 208.67.222.222.53:  udp 39
1479: 08:17:30.505512 802.1Q vlan#2 P0 192.168.60.20.51346 > 208.67.222.222.53:  udp 39
1484: 08:17:32.320356 802.1Q vlan#2 P0 192.168.60.20.49753 > 208.67.222.222.53:  udp 39
1493: 08:17:34.507297 802.1Q vlan#2 P0 192.168.60.20.51346 > 208.67.222.222.53:  udp 39
1498: 08:17:35.987299 802.1Q vlan#2 P0 192.168.60.20.50211 > 208.67.222.222.53:  udp 38
1504: 08:17:36.321623 802.1Q vlan#2 P0 192.168.60.20.49753 > 208.67.222.222.53:  udp 39
1512: 08:17:36.986475 802.1Q vlan#2 P0 192.168.60.20.50211 > 208.67.222.222.53:  udp 38
1513: 08:17:37.987406 802.1Q vlan#2 P0 192.168.60.20.50211 > 208.67.222.222.53:  udp 38
1521: 08:17:39.988001 802.1Q vlan#2 P0 192.168.60.20.50211 > 208.67.222.222.53:  udp 38
1940: 08:19:32.749732 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65521:  udp 91
2126: 08:19:46.482335 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61347:  udp 50
2169: 08:19:50.479681 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61347:  udp 50
2200: 08:19:54.485921 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61347:  udp 50
2235: 08:19:58.700113 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57408:  udp 50
2275: 08:20:02.700113 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57408:  udp 50
2300: 08:20:06.380931 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61124:  udp 139
2303: 08:20:06.697321 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57408:  udp 50
2310: 08:20:07.624113 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59656:  udp 184
2313: 08:20:08.222202 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63181:  udp 112
2314: 08:20:08.222263 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50007:  udp 70
2335: 08:20:09.764441 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51040:  udp 91
2345: 08:20:10.380839 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61124:  udp 139
2354: 08:20:11.624235 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59656:  udp 184
2361: 08:20:12.093821 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56090:  udp 131
2362: 08:20:12.202458 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63181:  udp 112
2363: 08:20:12.206364 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50007:  udp 70
2373: 08:20:12.696466 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51948:  udp 50
2384: 08:20:14.200886 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64562:  udp 112
2385: 08:20:14.205311 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63143:  udp 70
2387: 08:20:14.378062 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61124:  udp 139
2399: 08:20:22.627012 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50607:  udp 108
2407: 08:20:23.801136 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51512:  udp 195
2417: 08:20:24.940777 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62374:  udp 184
2423: 08:20:25.811771 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61821:  udp 91
2432: 08:20:26.646801 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60226:  udp 108
2433: 08:20:26.692606 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54228:  udp 50
2452: 08:20:27.801167 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51512:  udp 195
2461: 08:20:28.941510 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62374:  udp 184
2463: 08:20:29.230990 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52123:  udp 139
2465: 08:20:29.912260 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61877:  udp 65
2467: 08:20:30.000976 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57311:  udp 112
2474: 08:20:30.646664 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60226:  udp 108
2476: 08:20:30.689737 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54228:  udp 50
2491: 08:20:31.800678 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51512:  udp 195
2500: 08:20:32.938428 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62374:  udp 184
2503: 08:20:33.229037 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52123:  udp 139
2507: 08:20:33.444541 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51060:  udp 70
2512: 08:20:33.909590 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61877:  udp 65
2514: 08:20:34.001296 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57311:  udp 112
2522: 08:20:34.646511 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60226:  udp 108
2524: 08:20:34.690027 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54228:  udp 50
2530: 08:20:35.997705 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52341:  udp 112
2538: 08:20:37.228656 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52123:  udp 139
2540: 08:20:37.441886 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51060:  udp 70
2544: 08:20:37.909926 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61877:  udp 65
2548: 08:20:38.001113 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57311:  udp 112
2555: 08:20:38.651318 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56407:  udp 108
2561: 08:20:39.440818 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53603:  udp 70
2569: 08:20:39.997857 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52341:  udp 112
2575: 08:20:41.228519 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63240:  udp 185
2578: 08:20:41.446708 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51060:  udp 70
2589: 08:20:42.646664 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56407:  udp 108
2598: 08:20:43.440666 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53603:  udp 70
2604: 08:20:43.997354 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52341:  udp 112
2618: 08:20:45.163275 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63149:  udp 65
2619: 08:20:45.227817 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63240:  udp 185
2621: 08:20:45.251924 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57764:  udp 112
2626: 08:20:46.130547 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61026:  udp 195
2632: 08:20:46.643567 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56407:  udp 108
2638: 08:20:47.440742 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53603:  udp 70
2644: 08:20:48.162879 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63149:  udp 65
2646: 08:20:48.251512 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57764:  udp 112
2648: 08:20:48.694986 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49312:  udp 70
2652: 08:20:49.130867 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61026:  udp 195
2654: 08:20:49.228625 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63240:  udp 185
2663: 08:20:51.251146 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61384:  udp 112
2666: 08:20:51.647091 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52622:  udp 108
2667: 08:20:51.694589 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49312:  udp 70
2670: 08:20:52.160193 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63149:  udp 65
2674: 08:20:52.251360 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57764:  udp 112
2679: 08:20:53.100306 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56042:  udp 131
2680: 08:20:53.129448 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61026:  udp 195
2685: 08:20:54.250765 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61384:  udp 112
2687: 08:20:54.646161 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52622:  udp 108
2689: 08:20:54.696726 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52496:  udp 70
2691: 08:20:55.697412 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49312:  udp 70
2693: 08:20:56.097971 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56042:  udp 131
2700: 08:20:57.693369 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52496:  udp 70
2703: 08:20:58.250109 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61384:  udp 112
2705: 08:20:58.646008 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52622:  udp 108
2708: 08:21:00.097819 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56042:  udp 131
2713: 08:21:01.693308 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52496:  udp 70
2718: 08:21:02.823626 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63251:  udp 91
2719: 08:21:02.948177 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51292:  udp 70
2722: 08:21:03.646023 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63250:  udp 108
2729: 08:21:05.947399 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51292:  udp 70
2734: 08:21:06.648678 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63250:  udp 108
2743: 08:21:08.911467 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61647:  udp 195
2744: 08:21:08.946865 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60298:  udp 70
2748: 08:21:09.950069 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51292:  udp 70
2751: 08:21:10.643521 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63250:  udp 108
2754: 08:21:11.910627 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61647:  udp 195
2756: 08:21:11.946530 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60298:  udp 70
2767: 08:21:15.130623 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61338:  udp 117
2770: 08:21:15.646527 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51375:  udp 108
2774: 08:21:15.909453 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61647:  udp 195
2776: 08:21:15.943844 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60298:  udp 70
2783: 08:21:17.200947 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64763:  udp 70
2787: 08:21:18.130104 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61338:  udp 117
2790: 08:21:18.645565 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51375:  udp 108
2793: 08:21:20.198033 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64763:  udp 70
2799: 08:21:22.127434 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61338:  udp 117
2802: 08:21:22.513309 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51759:  udp 70
2803: 08:21:22.643460 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51375:  udp 108
2805: 08:21:23.197652 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49516:  udp 70
2811: 08:21:24.202885 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64763:  udp 70
2814: 08:21:24.904906 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60682:  udp 236
2817: 08:21:25.510471 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51759:  udp 70
2821: 08:21:26.196797 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49516:  udp 70
2825: 08:21:27.646023 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59714:  udp 108
2827: 08:21:27.883941 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60682:  udp 236
2833: 08:21:29.407174 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60724:  udp 65
2834: 08:21:29.510273 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51759:  udp 70
2838: 08:21:30.196629 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49516:  udp 70
2843: 08:21:30.645703 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59714:  udp 108
2844: 08:21:30.883072 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53426:  udp 236
2846: 08:21:31.451636 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62205:  udp 70
2848: 08:21:31.886230 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60682:  udp 236
2851: 08:21:32.406946 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60724:  udp 65
2858: 08:21:33.882171 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53426:  udp 236
2862: 08:21:34.451209 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62205:  udp 70
2864: 08:21:34.642941 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59714:  udp 108
2871: 08:21:35.948116 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60127:  udp 195
2872: 08:21:36.406595 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60724:  udp 65
2875: 08:21:36.909331 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65140:  udp 222
2877: 08:21:37.449866 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59320:  udp 70
2878: 08:21:37.880005 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53426:  udp 236
2883: 08:21:38.456137 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62205:  udp 70
2884: 08:21:38.944699 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60127:  udp 195
2886: 08:21:39.888427 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65140:  udp 222
2890: 08:21:40.449485 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59320:  udp 70
2893: 08:21:41.321714 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62421:  udp 237
2899: 08:21:42.885528 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60796:  udp 222
2900: 08:21:42.945065 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60127:  udp 195
2904: 08:21:43.657345 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50140:  udp 65
2906: 08:21:43.890731 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65140:  udp 222
2909: 08:21:44.298278 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62421:  udp 237
2912: 08:21:44.449531 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59320:  udp 70
2919: 08:21:45.704828 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50687:  udp 70
2920: 08:21:45.884658 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60796:  udp 222
2925: 08:21:46.657497 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50140:  udp 65
2928: 08:21:47.297958 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57907:  udp 237
2930: 08:21:48.300582 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62421:  udp 237
2934: 08:21:48.703653 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50687:  udp 70
2937: 08:21:49.831789 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57908:  udp 91
2938: 08:21:49.884491 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60796:  udp 222
2942: 08:21:50.297714 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57907:  udp 237
2943: 08:21:50.657299 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50140:  udp 65
2946: 08:21:51.703119 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55290:  udp 70
2950: 08:21:52.706308 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50687:  udp 70
2951: 08:21:53.303741 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53899:  udp 237
2952: 08:21:54.297363 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57907:  udp 237
2956: 08:21:54.702402 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55290:  udp 70
2960: 08:21:56.302810 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53899:  udp 237
2965: 08:21:57.908095 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60934:  udp 117
2968: 08:21:58.702035 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55290:  udp 70
2972: 08:21:59.302428 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63799:  udp 237
2975: 08:21:59.977564 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51380:  udp 76
2979: 08:22:00.307631 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53899:  udp 237
2984: 08:22:00.907667 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60934:  udp 117
2986: 08:22:01.284164 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51226:  udp 108
2990: 08:22:02.302688 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63799:  udp 237
2993: 08:22:02.956646 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51380:  udp 76
2995: 08:22:02.987848 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55596:  udp 195
3001: 08:22:04.283783 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51226:  udp 108
3004: 08:22:04.907072 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60934:  udp 117
3009: 08:22:05.955822 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64295:  udp 76
3010: 08:22:05.984934 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55596:  udp 195
3012: 08:22:06.301864 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63799:  udp 237
3016: 08:22:06.958934 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51380:  udp 76
3022: 08:22:08.280640 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51226:  udp 108
3029: 08:22:08.955440 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64295:  udp 76
3032: 08:22:09.910627 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57632:  udp 117
3033: 08:22:09.987238 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55596:  udp 195
3035: 08:22:10.246538 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60678:  udp 131
3042: 08:22:11.959514 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62946:  udp 76
3044: 08:22:12.909758 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57632:  udp 117
3046: 08:22:12.952709 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64295:  udp 76
3049: 08:22:13.245653 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60678:  udp 131
3056: 08:22:14.956554 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62946:  udp 76
3062: 08:22:16.906996 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57632:  udp 117
3065: 08:22:17.248507 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60678:  udp 131
3068: 08:22:17.957820 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57216:  udp 76
3071: 08:22:18.956493 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.62946:  udp 76
3077: 08:22:20.958004 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57216:  udp 76
3083: 08:22:23.961543 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64402:  udp 76
3086: 08:22:24.957271 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57216:  udp 76
3089: 08:22:25.054562 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60597:  udp 237
3092: 08:22:26.958675 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64402:  udp 76
3096: 08:22:28.046246 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60597:  udp 237
3100: 08:22:29.960353 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51515:  udp 76
3102: 08:22:30.029570 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51928:  udp 195
3105: 08:22:30.958049 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64402:  udp 76
3108: 08:22:31.020689 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54204:  udp 70
3110: 08:22:31.032819 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64172:  udp 237
3113: 08:22:32.036069 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60597:  udp 237
3115: 08:22:32.960002 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51515:  udp 76
3117: 08:22:33.024214 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51928:  udp 195
3120: 08:22:34.019850 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54204:  udp 70
3122: 08:22:34.032392 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64172:  udp 237
3126: 08:22:35.963649 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58593:  udp 76
3127: 08:22:36.918943 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52177:  udp 117
3128: 08:22:36.957302 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51515:  udp 76
3131: 08:22:37.024031 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51928:  udp 195
3134: 08:22:38.020155 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54204:  udp 70
3137: 08:22:38.034971 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64172:  udp 237
3138: 08:22:38.963451 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58593:  udp 76
3141: 08:22:39.916075 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52177:  udp 117
3144: 08:22:41.962337 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55848:  udp 76
3147: 08:22:42.905608 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54153:  udp 260
3149: 08:22:42.965037 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58593:  udp 76
3153: 08:22:43.915739 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52177:  udp 117
3159: 08:22:44.961498 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55848:  udp 76
3162: 08:22:45.904860 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54153:  udp 260
3165: 08:22:46.842790 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54154:  udp 91
3169: 08:22:47.966121 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50849:  udp 76
3170: 08:22:48.894881 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55040:  udp 236
3171: 08:22:48.918317 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63098:  udp 117
3172: 08:22:48.959026 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55848:  udp 76
3177: 08:22:49.905165 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54153:  udp 260
3180: 08:22:50.965282 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50849:  udp 76
3182: 08:22:51.894179 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55040:  udp 236
3183: 08:22:51.917417 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63098:  udp 117
3188: 08:22:53.964839 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64023:  udp 76
3192: 08:22:54.893157 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57213:  udp 236
3193: 08:22:54.963039 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50849:  udp 76
3199: 08:22:55.898970 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55040:  udp 236
3200: 08:22:55.917707 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63098:  udp 117
3205: 08:22:56.963954 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64023:  udp 76
3207: 08:22:57.064953 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56311:  udp 195
3211: 08:22:57.892760 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57213:  udp 236
3219: 08:22:59.968089 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63271:  udp 76
3220: 08:23:00.064877 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56311:  udp 195
3223: 08:23:00.899382 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52883:  udp 222
3224: 08:23:00.918241 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63492:  udp 65
3225: 08:23:00.964015 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64023:  udp 76
3228: 08:23:01.892562 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57213:  udp 236
3233: 08:23:02.967235 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63271:  udp 76
3237: 08:23:03.898650 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52883:  udp 222
3240: 08:23:03.917433 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63492:  udp 65
3242: 08:23:04.061871 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.56311:  udp 195
3248: 08:23:05.966853 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49426:  udp 76
3249: 08:23:06.105661 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59421:  udp 260
3250: 08:23:06.897582 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54348:  udp 222
3253: 08:23:06.969966 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63271:  udp 76
3254: 08:23:07.104395 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59421:  udp 260
3256: 08:23:07.900817 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52883:  udp 222
3258: 08:23:07.917188 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63492:  udp 65
3260: 08:23:08.121102 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59421:  udp 260
3262: 08:23:08.965968 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49426:  udp 76
3267: 08:23:09.894790 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54348:  udp 222
3269: 08:23:10.103510 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59421:  udp 260
3273: 08:23:12.966594 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.49426:  udp 76
3276: 08:23:13.894591 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54348:  udp 222
3278: 08:23:14.105325 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59421:  udp 260
3283: 08:23:15.168524 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64971:  udp 65
3290: 08:23:18.168692 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64971:  udp 65
3297: 08:23:22.167975 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64971:  udp 65
3300: 08:23:24.102426 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59518:  udp 195
3304: 08:23:25.966487 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63456:  udp 70
3311: 08:23:27.101526 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59518:  udp 195
3317: 08:23:28.965602 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63456:  udp 70
3320: 08:23:29.418755 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63330:  udp 117
3326: 08:23:31.101343 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59518:  udp 195
3329: 08:23:31.919706 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52792:  udp 108
3330: 08:23:31.962825 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51619:  udp 70
3331: 08:23:32.415872 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63330:  udp 117
3337: 08:23:32.968532 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63456:  udp 70
3342: 08:23:34.921384 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52792:  udp 108
3343: 08:23:34.962093 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51619:  udp 70
3347: 08:23:36.416161 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.63330:  udp 117
3355: 08:23:38.918653 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52792:  udp 108
3357: 08:23:38.961681 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51619:  udp 70
3362: 08:23:40.219242 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52373:  udp 70
3367: 08:23:41.420983 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60196:  udp 117
3368: 08:23:41.426140 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52680:  udp 70
3374: 08:23:43.218341 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52373:  udp 70
3378: 08:23:44.417840 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60196:  udp 117
3381: 08:23:44.422967 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52680:  udp 70
3391: 08:23:46.217991 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51938:  udp 70
3398: 08:23:47.220706 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52373:  udp 70
3403: 08:23:48.418160 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60196:  udp 117
3406: 08:23:48.423058 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52680:  udp 70
3411: 08:23:49.217655 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51938:  udp 70
3422: 08:23:51.141533 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55883:  udp 195
3433: 08:23:53.214939 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51938:  udp 70
3440: 08:23:54.145637 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55883:  udp 195
3441: 08:23:54.469442 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53554:  udp 70
3450: 08:23:57.469061 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53554:  udp 70
3455: 08:23:58.140999 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55883:  udp 195
3461: 08:24:00.468695 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58757:  udp 70
3464: 08:24:01.468969 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53554:  udp 70
3469: 08:24:03.467810 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58757:  udp 70
3480: 08:24:07.427132 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51241:  udp 117
3483: 08:24:07.467733 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58757:  udp 70
3487: 08:24:08.722130 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53884:  udp 70
3491: 08:24:10.430275 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51241:  udp 117
3496: 08:24:11.722237 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53884:  udp 70
3505: 08:24:14.426064 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.51241:  udp 117
3507: 08:24:14.720864 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59532:  udp 70
3511: 08:24:14.906035 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
3515: 08:24:15.724068 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.53884:  udp 70
3521: 08:24:17.720498 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59532:  udp 70
3523: 08:24:18.181677 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52120:  udp 195
3526: 08:24:19.428612 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58045:  udp 117
3528: 08:24:19.887054 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
3531: 08:24:21.178304 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52120:  udp 195
3535: 08:24:21.720299 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59532:  udp 70
3538: 08:24:22.428231 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58045:  udp 117
3540: 08:24:22.975321 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55981:  udp 70
3542: 08:24:24.885620 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
3544: 08:24:25.178777 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52120:  udp 195
3549: 08:24:25.977915 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55981:  udp 70
3550: 08:24:26.428093 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.58045:  udp 117
3553: 08:24:26.571671 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54072:  udp 108
3557: 08:24:28.974055 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61441:  udp 70
3558: 08:24:29.571351 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54072:  udp 108
3560: 08:24:29.885864 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
3562: 08:24:29.979273 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.55981:  udp 70
3564: 08:24:31.973139 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61441:  udp 70
3566: 08:24:33.573639 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54072:  udp 108
3572: 08:24:35.973963 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61441:  udp 70
3575: 08:24:37.225574 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54778:  udp 70
3578: 08:24:40.227695 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54778:  udp 70
3586: 08:24:43.224780 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61415:  udp 70
3588: 08:24:44.225009 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.54778:  udp 70
3594: 08:24:45.218357 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59345:  udp 195
3599: 08:24:46.225909 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61415:  udp 70
3603: 08:24:48.217472 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59345:  udp 195
3605: 08:24:48.437309 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64239:  udp 117
3609: 08:24:50.223697 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.61415:  udp 70
3612: 08:24:51.435310 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64239:  udp 117
3614: 08:24:51.478262 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60625:  udp 76
3616: 08:24:52.217807 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59345:  udp 195
3619: 08:24:52.798359 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57029:  udp 70
3622: 08:24:54.477926 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60625:  udp 76
3625: 08:24:55.433113 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.64239:  udp 117
3629: 08:24:55.798222 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57029:  udp 70
3634: 08:24:57.477499 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65124:  udp 76
3638: 08:24:58.483281 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.60625:  udp 76
3642: 08:24:59.797306 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57029:  udp 70
3645: 08:25:00.438408 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50075:  udp 117
3646: 08:25:00.478857 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65124:  udp 76
3651: 08:25:03.435371 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50075:  udp 117
3652: 08:25:03.480749 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57210:  udp 76
3654: 08:25:04.474020 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.65124:  udp 76
3660: 08:25:06.480352 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57210:  udp 76
3662: 08:25:07.435066 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.50075:  udp 117
3667: 08:25:09.479497 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52037:  udp 76
3670: 08:25:10.487187 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.57210:  udp 76
3673: 08:25:12.258485 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.59263:  udp 195
3674: 08:25:12.478612 802.1Q vlan#2 P0 208.67.222.222.53 > 172.26.20.22.52037:  udp 76
mxfw(config)# sho cap capo
16 packets captured
   9: 08:24:14.880508 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
  10: 08:24:14.906004 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
  11: 08:24:19.860780 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
  12: 08:24:19.887023 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
  13: 08:24:24.859971 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
  14: 08:24:24.885574 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
  15: 08:24:29.859147 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
  16: 08:24:29.885833 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
16 packets shown
mxfw(config)# sho cap capdmz
ERROR: Capture does not exist
0 packet captured
0 packet shown
mxfw(config)#
ASA 5505 ver 8.4 DMZ to Outside not working
Hello Gerald,
As you saw there are a lot of drops for DNS packets due to Resource limitations. Are you having issues with Any other traffic on your network?
Back to the ICMP test
Can you clear all of the captures and to the test once more time
clear cap /all
ping and share
show cap capo
show cap capd
Cheers,
Julio,
I don't have anything running yet so I don't know why it would indicate limited resources (I did notice that though).
I will clear everything and perform the dumps again in the morning.
Thank you again,
Jerry
Julio,
Here are teh results after clearing the captures.
Thank you for your assistance,
Jerry
mxfw# sho cap capo
8 packets captured
   1: 10:04:52.345486 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   2: 10:04:52.382899 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   3: 10:04:57.205204 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   4: 10:04:57.231219 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   5: 10:05:02.204335 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   6: 10:05:02.231707 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
   7: 10:05:07.203541 802.1Q vlan#2 P0 192.168.1.231 > 208.67.222.222: icmp: echo request
   8: 10:05:07.229785 802.1Q vlan#2 P0 208.67.222.222 > 192.168.1.231: icmp: echo reply
8 packets shown
mxfw# sho cap capd
0 packet captured
0 packet shown
mxfw# sho cap asp | include 208.67.222.222
  35: 10:04:52.382930 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
  40: 10:04:57.231250 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
  47: 10:05:02.231753 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
  57: 10:05:07.229831 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
mxfw#
I added:
nat (dmz,any) source static DMZ_Network DMZ_Network destination static Generic_All_Network Generic_All_Network
and ran the capture again after clearing and still get the no adjacency on some ping attempts but not others:
   3: 10:25:43.558030 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
   5: 10:25:48.457953 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
   6: 10:25:53.458457 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
  13: 10:25:58.456488 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply Drop-reason: (no-adjacency) No valid adjacency
  76: 10:27:20.837526 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
  79: 10:27:25.437080 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
  86: 10:27:30.456565 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
  93: 10:27:35.436073 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
135: 10:28:09.571854 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
142: 10:28:14.426216 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
149: 10:28:19.423699 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
162: 10:28:24.441246 802.1Q vlan#2 P0 208.67.222.222 > 172.26.20.22: icmp: echo reply
mxfw(config)#
Actually do
Can U include the output of show version?
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
I take that back, I didn't realize my WiFi was on.
Still working on this.
That's what I get for switching between issues and not checking the setup completely.
Sorry for the confusion.
Jerry
Naveen & Julio,
Thank you both for your input. I am away from the office that has the equipment until tomorrow around 8am.
I will gather the requested information at that time and post to this discussion.
Thank you both again.
Jerry
Sure, just keep us updated!
Cheers,
I posted the requested information yesterday morning,  but instead of it being at the bottom it put the post above.
Jerry
Hi Jerry,
Its asymmetric routing that is happening here.
So
Source-----Dmz-ASA-outside---Internet---destination
If the host is connected on DMZ interface, why we are not seeing any traffic ingress to that interface; however we can see the traffic leaving outside interface. Firewall is dropping the traffic as is unable to find the source interface of the traffic.
Any specific Reasons why we are using E0/5 as trunk and if we can create a seperate interface for DMZ and DMZ2.
Please try this and let us know how it goes also check for the ouput of and see if we are getting the arp for the source
192.168.1.231 from dmz interface only.
show arp | in dmz
Cheers,
Naveen
Naveen,
Here is the DMZ ARP:
mxfw(config)# show arp | in dmz
        dmz 172.26.20.21 b888.e3fd.0b90 30
I am using 2 VLANs on my switch for Guests - one is wired and the other is wireless. I am trying to keep them separate because the wireless are any guest that might be at our restaurant that is getting on WiFi. The wired is for our Private Dining Rooms that vendors may need access and I don't want the wireless being able to see the wired network in that situation.
I have ports on my 3560s that are assigned to VLAN 20 (Guest Wired) and VLAN 22 (Guest Wireless). I am not routing those addresses within the 3560s (one 3560 is setup as a L3 switch). Those VLANs are being L2 switched to the ASA via the trunk to save ports (I tried separating them and used 2 ports on the ASA and it still didn't work). The ASA is providing DCHP for those VLANs and the routing for the DMZ VLANs. I can ping each of the gateways (which are the VLANs on the ASA from devices on the 3560s - 172.26.20.1 and 172.26.22.1. I have those in my DMZ off the ASA so it can control and route the data.
The 3560 is routing for my Corp VLANs. So far I have tested the Wired VLAN 10 (10.1.10.0/24) and it is working and gets to the Internet.  I have a default route (0.0.0.0 0.0.0.0) from the L3 switch to e0/1 on the ASA and e0/1 is an Inside interface.
E0/0 on the ASA is my Outside interface and gets it IP from the upstream router (will be an AT&T router/modem when I move it to the building).
So for a simple diagram:
PC (172.26.20.21/24) -----3560 (L2) ------Trunk----(VLAN 20 - DMZ/ VLAN 22 - DMZ2)---- ASA -----Outside ------- Internet (via router/modem)
Let me know if this makes sense to you.
Thank you for your assistance.
Jerry
PS - I just created e0/4 as an access port for VLAN 20 and connected my computer directly to that port. The computer still cannot ping my DNS provider address: 208.67.222.222. So it is the same situation that I am not getting to the internet.
Hello Gerald,
So the ASA learns the host sending the ICMP traffic is behind the DMZ interface,
Can you do
ping dmz 172.16.20.22
Here is what I want u to do
no nat (dmz,any)  source static DMZ_Network DMZ_Network destination static Generic_All_Network Generic_All_Network
nat (dmz,outside )  2source static DMZ_Network DMZ_Network
no cap capo
no cap capd
cap capin interface dmz match icmp any host 4.2.2.2
cap capout interface outside match icmp any host 4.2.2.2
Then from that client try to ping 4.2.2.2
afterwards
show cap capin
show cap capout
show cap asp | include 4.2.2.2
show logging | include 4.2.2.2
Julio,
I will look at that tomorrow. Also found some things in the switch to change as well.
Open DNS (208.67.222.222) should work just as well as 4.2.2.2 (I can get to the address from the Inside network) but I will try 4.2.2.2 as well.
Thanks again, I will gather this information in the morning and get it to you. I have been up since 4pm yesterday and am no longer at the site.
Jerry
Sure,
I used 4.2.2.2 but you could use whatever you want.
Cheers,
Julio,
While working on another issue, I had a second set of eyes review the configs in my switches and one of the switches hadn't fully had it's VLAN 20 & 22 information removed, therefore it was causing this issue.
Also, becuase I hadn't cleared the AQRP table of my computer when I moved it from the switch to be directly connected to the ASA, it was still trying to access the switch which hadn't been configured to support the DMZ traffic any longer.
Sorry for the confusion.  Once again, thak you for your assistance.
Jerry
Hello Gerald,
It is our pleasure to help,
Jcarvaja
1049
