Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 VPN RA help
Trying to configure remote access via Preshared secret..VPN client connects fine, but I am unable to connect to the internal LAN. When I turn on logging it is complaining that I have no translation rule outside interface to internal LAN. I have tried bypassing NAT via NAT 0 and ACL but no success.
Any ideas ??
Thanks Dave
Gold
Re: ASA 5505 VPN RA help
so your nat 0 statement/acl has your LAN network range for the source address and your vpn client address range for the destination part?
is sysopt connection permit-vpn/ipsec turned on?
(sh run sysopt)
if not, is your outside-to-inside ACL allowing access from the remote access address range?
Thanks, it was the Nat 0 acl, had to swap it around and make the source address the internal LAN.
Cheers
Dave
105
