ASA 5505 w/ Verizon DSL
Hello all,
I'm pretty decent in the world of Cisco but I'm having trouble getting traffic to flow out with a ASA 5505 on Verizon DSL. I have a static IP with Verizon and I'm using their Westfall 7500 modem/router as a routed bridge into my network.
The data flow goes likes this: Westfall 7500 > Cisco Catalyst Switch > ASA 5505
The switch has a inside and outside VLAN. The router and the outside interface on the ASA reside in the outside VLAN, everything else is on the inside VLAN.
At this point I have a very basic configuration, I think the issue may reside in one of two areas:
1) The outside interface is set to the static IP that Verizon gave me
2) I'm routing the outside interface to the Verizon gateway, basically my static IP but it ends in .1 (route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1)
Should I be routing the outside interface elsewhere? Are there any other issues that anyone can think of?
Just as a side note, all the speed/duplex settings seem to match, I've had trouble with that in the past...
Re: ASA 5505 w/ Verizon DSL
the route you mentioned looks good.
As you are pointing all the traffic coming on the ASA to go to it's next hop which is the internet router.
If you've got that upstream modem in bridge mode and configured the static on the outside interface of the ASA there should be no issue's for traffic reaching out to the internet.
Is your traffic outbound ? from LAN to the internet.
Can you ping internet from the ASA?
1. try to ping 4.2.2.2 from the ASA
if you are able to reach that then half the work is done.
Now we need to see what's the issue with the ASA.
Can you share the configuration from the ASA5505 so that we can make sure it is configured fine to pass all the traffic out.
Thanks for the response puseth, here is the config:
ASA Version 7.2(4)
hostname [removed]
domain-name [removed]
enable password [removed] encrypted
passwd [removed] encrypted
names
dns-guard
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 71.[removed].8 255.255.255.248
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
pager lines 24
logging enable
logging trap debugging
logging asdm notifications
logging host inside 192.168.1.165
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit 192.168.1.0 255.255.255.0 inside
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 71.[removed].1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 15
console timeout 0
dhcp-client client-id interface outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:95fb6708e9b980eb188aea253103275f
: end
629
