Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505Trunking port issue
Hello everyone,
I've recently added 5 vlans into my network and turned my eth0/1 port which goes to my switch into a trunk port. Since this change I haven't been able to get out to the internet at all. From my switch I am able to ping all of the vlan IP addresses assigned to the ASA, and vice-versa. I have a feeling that the problem maybe with the ACLs, but I don't know exactly what to look for. I've attached my configuration file for all of you to look at. Any help is much appreciated.
Everyone's tags (1)
1 ACCEPTED SOLUTION
First of all, remove the
First of all, remove the command switchport access vlan 4 from the interface
interface Ethernet0/1
 switchport trunk allowed vlan 4,10,13-14,50-51
 switchport mode trunk
Also I notice you do not have any NAT statement configured, please add the following command:
object network obj_any
  nat (any,outside) dynamic interface
Though you should have specific dynamic NAT for each network, this is a quick and easy solution to configure NAT.
Try making these changes and then test, and let us know how it goes.
Please remember to select a correct answer and rate helpful posts
Please remember to rate and select a correct answer
What license do you have
What license do you have installed on your ASA (show version)?  If you have the base license then you will need to uprade to the security plus license.
Community Member
Hello Marius,The device has
Hello Marius,
The device has the security plus license
Community Member
Thank you Marius, those 2
Thank you Marius, those 2 commands did the trick.
45
