ASA-5510: Adding another static nat issue.
I'm trying to add another static nat translation onto the ASA. There's already one static nat to another host. Wouldn't I just copy the same static and change the IP's? Tried it and it gave me a error. Not sure what else I'm suppose to add. Kinda lost.
error: router(config)# static (inside,backup) 214.24.29.114 10.20.1.20 netmask 255.255.255.255 0 0
ERROR: Static PAT using the interface requires the use of the 'interface' keyword instead of the interface IP address
1 ACCEPTED SOLUTION
Re: ASA-5510: Adding another static nat issue.
try static (inside,backup) tcp interface www 10.20.1.20 www netmask 255.255.255.255. change the port to whatever you would like to allow.
here's the current config file.
ASA Version 8.0(3)
hostname asa510-01
domain-name corp.com
enable password xxxxxxxxxxxx encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 214.x.x.114 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.20.1.254 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
access-list outside_1_cryptomap extended permit ip 10.20.1.0 255.255.0.0 10.0.0.0 255.0.0.0
access-list inside_nat0_outbound extended permit ip 10.20.1.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list outside_access_in remark allow public to http
access-list outside_access_in extended permit tcp any host 214.24.29.115 eq www
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
logging host inside 10.1.xx.xx
mtu outside 1500
mtu inside 1500
ip verify reverse-path interface inside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.20.1.0 255.255.255.0
static (inside,outside) 214.24.29.115 10.20.1.10 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 214.24.29.113 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa-server LIST1 protocol tacacs+
key xxxxxxxxx
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa accounting enable console LIST1
http server enable
http 10.20.10.0 255.255.255.0 inside
http 207.40.115.253 255.255.255.255 outside
snmp-server host inside 10.1.11.45 community 1232344
snmp-server location xxxxxxxx
no snmp-server contact
snmp-server community 123cabaf3a
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 207.40.115.1
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
console timeout 5
management-access inside
threat-detection basic-threat
threat-detection statistics
tunnel-group 207.40.115.1 type ipsec-l2l
tunnel-group 207.40.115.1 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect netbios
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect tftp
inspect xdmcp
inspect http
inspect icmp
inspect snmp
service-policy global_policy global
prompt hostname context
Green
Don't see a "backup" interface in the config. It wants you to use the "interface" keyword instead of the ip address. For example...
static (inside,outside) interface 10.20.1.20 netmask 255.255.255.255
...because 214.24.29.114 is the ip address of the interface.
calvinz,
also according to your config, the device hostname you are trying to do NAT is "router" while the hostname for your ASA is "asa510-01". make sure you are working on the correct device. NAT commands work differently on ASA/Routers.
Francisco.
Sorry, here's the right config and it does have backup as a interface.
ASA Version 8.0(3)
hostname asa510-01
names
nameif backup
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
arp timeout 14400
global (backup) 1 interface
static (inside,backup) 214.24.29.115 10.20.1.10 netmask 255.255.255.255
access-group outside_access_in in interface backup
route backup 0.0.0.0 0.0.0.0 214.24.29.113 1
key xxxxxxxxx
http server enable
http 207.40.115.253 255.255.255.255 backup
crypto map outside_map interface backup
crypto isakmp enable backup
encryption 3des
hash sha
group 2
lifetime 86400
console timeout 5
pre-shared-key *
parameters
inspect ftp
inspect netbios
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect tftp
inspect xdmcp
inspect http
inspect icmp
inspect snmp
I'm in the correct router. I just forgot what I named the router.
I tried using backup as a interface and got this error:
asa510-01(config)# static (inside,backup) interface 10.20.0.20 netmask 255.255.255.255
WARNING: static redirecting all traffics at backup interface;
WARNING: all services terminating at backup interface are disabled.
So it seems like I might have to create a new interface or something?
then what adam suggested will work for you. have you tried it? does it work?
Francisco.
i think the reason why you have this problem is because you already have "global (backup) 1 interface". (Translating already using the outside interface for 10.20.1.0 255.255.255.0. try using another public ip for one-one static translation.
Is there anyway around it w/o having to have another public IP?
unless you use static with PAT.
Example below shows how to configure static PAT for an internal web server located at 192.168.10.10 The web client on the public network will connect to the server using the public IP address of the security appliance using the default web (TCP port 80)
static (inside,outside) tcp interface www 192.168.10.10 www netmask 255.255.255.255
thanks, i'll give that try. it seems like i'm talking to someone here that doesn't understand what they are asking. I'll check with the 3rd party on what they want. will keep you posted. thanks for the help..
i was able to put in a static nat with another public IP. thanks for your help.
I'm having a access issue. wonder if you guys can see if its being block somewhere else. i already wrote up a ACL for the access but it's still being denied. same router.
access-list outside_access_in line 11 extended permit tcp any 214.16.68.192 255.255.255.192 eq 3389 (hitcnt=0)
access-list outside_access_in line 12 extended permit tcp any 214.16.68.192 255.255.255.192 (hitcnt=0)
Deny tcp src backup:214.16.68.246/4225 dst inside:214.24.29.115/3389 by access-group "outside_access_in" [0x0, 0x0]
try
access-list outside_access_in extended permit tcp any host 214.16.68.192 eq 3389
Francsico
394
