ASA 5510 and Failover
I have 2 ASA 5510 SEC-BUN
I want to enable failover.
I have this configuration :
Ethernet 0/0 : Outside
Ethernet 0/1 : Inside
Ethernet 0/2 : DMZ
I follow the example : How to configure Failover on ASA, and i can read that i need two interface :
One for Lan Failover Interface and One for State Failover Interface.
I have no more two Interface , I have only one free (Ethernet 0/3).
The Cisco documentation do not recommend to use the Management Interface.
Thanks for your help
Gold
Re: ASA 5510 and Failover
you can use eth0/3 as both the failover interface and the stateful interface.
First you configure failover in primary firewall(do not power on the sec.)
you have to put this commands:
interface Ethernet0/3
description LAN/STATE Failover Interface
speed 100
duplex full
failover
failover lan unit primary
failover lan interface FAILOVER_ETH3 ethernet0/3
failover lan enable
failover polltime unit 5 holdtime 15
failover link FAILOVER_ETH3 Ethernet0/3
failover interface ip FAILOVER_ETH5 192.168.1.1 255.255.255.0 standby 192.168.1.2
After entering these commands power on the sec. device and issue the command:
failover lan unit secondary
I think this is all you required.
413
