Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5510 anyconnect premium
Dears,
kindly advise if  ASA 5510 (AnyConnect Premium - SSL/IPsec VPN Edition) with SKU: ASA-VPNP-5510= is compatible with MAC systems?
thanks.
ALL ASA are compatible with MAC. To make the Anyconnect work with MAC you just needed the anyconnect image for MAC in the flash.
In case if you just needed to know that will you be able to connect ANyconnect using a MAC machine on this ASA 5510 teh answer is YES.
Jeet Kumar
Silver
Jeet is saying correct. We can connect anyconnect client from any supported OS's on ASA. We just need to put the anyconnect image in flash of ASA and called them in webvpn configuration.
we can do it in following way:-
webvpn
anyconnect image disk0:/anyconnect-win-2.5.6005-k9.pkg 1
anyconnect image disk0:/anyconnect-macosx-i386-3.1.04066-k9.pkg 2.
Naresh
thank you all
188
