Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 blacklist not working.
I have a ASA 5510. I'm trying to set up a blacklist. I have added this for the inbound access-list (access-group outbound in interface inside), but it is not working. Any ideas?
object-group network BLACKLIST
 network-object host xx.xx.xx.xx
access-list inside extended deny ip object-group BLACKLIST any
1 ACCEPTED SOLUTION
Bronze
From what you have said, your
From what you have said, your access group statement seems to be referencing an ACL called outbound, but your ACL is called inside.
Bronze
Community Member
Thanks for the reply. I didn
Thanks for the reply. I didn't do the configuration, and the naming is horrible. And my CLI skills are a little rusty. I changed the ACL, and it seems to be working. Thanks for taking a look.
Bronze
Glad it is working for you
Glad it is working for you now.
When something needs to be named, whether it is an ACL, Route Map, Class Map etc.. I tend to always reference an abbreviation in my name, e.g RM for route-map, CM for class-map
ip access-list extended ACL_DF
route-map RM_DF permit 10
match ip address ACL_DF
I think a lot of others will most likely follow the same, or similar.
32
