ASA 5510 connection and configuration
Hello all
I want to connect ASA firewall on my network. currently i have a router connected to a switch. How do i connect and configure the firewall to protect my network.
Hi ,  In present network
Hi ,
  In present network setup , if your router is not doing route advertisement via BGP . Connect your internet link directly to your ASA device and switch to your ASA inside interface
Do PATing accordingly .
For ASA version 8.4
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/112998-asa-1-int-00.html
For ASA Version less than 8.3
http://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/10138-19b.html
If you need any further help let me know .
Sandy
Hello SANTHOSHKUMAR SMy
My current network setup is attached. Where/how can i connect the ASA. I am still new to networking..kindly help
Hi ,  I am seeing VPN tunnel
Hi ,
 I am seeing VPN tunnel from your existing router , can you share me your router config ?? . What is your requirement , you want to replace router with asa / connect asa to existing router ??
Sandy
Hie Santhoshkumar SI want to
Hie Santhoshkumar S
I want to connect the ASA to current router and allow it to check packets from my entire network (HQ and other 5 sites).
But if its easy and wise to replace the router then it be fine.
I have sent the config o your inbox
62
