ASA 5510 - Failed to locate egress interface
having a bit of trouble setting up our 5510.  None of us have ever played with a firewall before.  We've got most of the basics covered.  I was able to get to the outside world to do a software update to the box, but my laptop that sits in the inside can't see the outside.  We only have the default access rules in place at the moment.  Our old ISA firewall rules don't really translate all that well to this new box.
Thanks.
Jeremy
Everyone's tags (3)
Hi Jeremy,
There can be a number of things, firstly I'd say check the following
1) Are you running nat-control (sh run nat-control)
2) Do you have any nats setup ( sh run nat, sh run global, sh run static)
3) Check your inside access-list if defined, if not ensure your inside security level is higher than your outside security level.
4) finaly try a packet-trace which should give you some cryptic output, but will help...
    packet-trace input inside icmp 192.168.1.16 8 0 4.2.2.2
(this will do a echo (type 8 code 0) request from interface named "inside" 192.168.1.16 to 4.2.2.2 and shows if its allowed or will be dropped, if the above doesnt help, post the output of this into the errr...post!
Cheers,
Rich
that's what it was.  Called tech support and they fixed it in about 10 min.
Thanks.
Same problem - was using an old Pix 501, and am having trouble getting the ASA to send internal traffic to the outside. I originally thought it was the lack of a default gateway, but that seems to be configured (When I try to manually set one up, I get a message it is already there).
I'm using ADSM to configure, but logging into the console gives the following config:
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.132 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
!                          inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
  inspect ftp
  inspect h323 h225
20240
