Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA 5510 failover
I have 2 ASA 5510 and i want to create failover between them.
The 2 ASAs have the Security Plus license and 3DES enable.
But when I try to create the failover i obtain the following error message "Hardware module compatibility for platform failed"
See the following "show ver" wich confirm the 2 ASA have an identical hardware and fonctionnality.
The only difference is:
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Hardware: ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Bronze
Re: ASA 5510 failover
You are probably trying to do that through ASDM, try it via CLI and it should work.
It happened to me. I dont know if it's an ASDM bug.
Issue the commands :
sh module
See if there is a module installed in one of the,If yes,hardware is not same and you would need to remove it from one of the units.
Do rate helpful posts.
Sushil
I resolve the problem.
One ASA was in mode single and the other in mode multiple.
Hello mathieuchanu,
I have the same issue.
Did you have done the configuration by CLI or ASDM?
404
