ASA 5510 Hairpin (I think) for VPN traffic
I've got a slight problem with a site to site vpn setup between site A and site B and the ability to authenticate against an RSA SecurID appliance located at Site A if the user VPNs in to Site B.
Basically, the setup is as follows:
Site A:
Cisco ASA 5510
VPN access set on the firewall to authenticate against site A RSA device.
Single Class C Subnet supernetted on /23 - the inside interface on the firewall is on this subnet
Site B:
Cisco ASA 5510
VPN access set on the firewall to authenticate against Site A RSA device.
Site A works beautifully, authenticates and allows access.
Site B hangs on 'contacting the security gateway'. When I try to ping Site A subnet from firewall B, I get no response, which I think is the problem.
I have set the 'same-security-traffic permit intra-interface' setting.
Any help would be much appreciated.
1 REPLY
Re: ASA 5510 Hairpin (I think) for VPN traffic
When you ping Site A subnet from firewall B, did you use the command
ping inside (LAN side of ASA) siteA ip..?
or just ping .
If there is working L2L tunnel between 2sites, ping (interface) ip should work.
TIA
MS
845
