ASA 5510 help
Let's say I have the following configured on my ASA 5510:
Internet
ASA-----DMZ
Catalyst 3560
LAN
interface ethernet1.99
nameif management
security-level 100
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.14
vlan 1
exit
interface ethernet1/1.100
nameif inside
ip address 192.168.2.1 255.255.255.0 standby 192.168.2.2
vlan 2
exit
As you can see the ASA has my users and servers are connected to vlan 2 and vlan 1 will be used for managing the routers, switches, and firewalls.
My question is the configuration for the firewall correct and what type of configuration would I need to do on the switch? whether i need to make the port on the switch as L3 which is connecting to inside interface of ASA.
Re: ASA 5510 help
Your config looks good.
Now whether we need a layer 2 switch or layer 3 switch well.... since your ASA has only one vlan to the inside interface..i think it would make do with a layer 2 interface and it would look at the mac addresses of the dest to transfer them accordingly
If someone could shed more light..
Shyam
Re: ASA 5510 help
HI,
My plan is to add more vlan in the inside interface. I have L3 switch with 2 switches for redundancy. How to configure the switch and ASA inside interface for the traffic to flow for all vlans between. Whether i can enable HSRP on the two switches and configure the vlan as hsrp which will connect to inside interface of ASA
pls help
Re: ASA 5510 help
Isn?t it a good idea to Configure Your L3 Switch your core VLAN and configure your Firewall as normal with DMZ.
Re: ASA 5510 help
I am not clear. can you explain in more details pls..
thanks
156
