Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5510 High Cpu usage caused by disptach unit
We have a cisco ASA 5510 running on Software Version 8.0(4)28.
Recently we are seeing high cpu usage as below
ABC-ASA# show cpu usage
CPU utilization for 5 seconds = 53%; 1 minute: 43%; 5 minutes: 45%
ABC-ASA#
and I have notice its becuase of dispatch unit
ABC-ASA# show processes cpu-usage non-zero sorted
PC         Thread       5Sec     1Min     5Min   Process
0817ff94   d442f92c    44.9%    41.1%    42.1%   Dispatch Unit
08b207ad   d4429aa4     2.5%     2.4%     2.3%   Logger
091c6c28   d442af70     0.1%     0.0%     0.0%   Checkheaps
ABC-ASA#
Please advise what should be the avarage cpu and Dispatch unit utilization in the peak connections time .
There is no average CPU usage for an ASA, that will depend of your enviroment (how much traffic is going through the ASA, How many features you have enabled on the box, how many inspection engines are doing DPI, etc ,etc ,etc)
So my recomendation would be:
-Get a baseline of what is your usual CPU usage and from there start monitoring the box, then if you see the CPU incrementing you can let us know,
-FYI Dispatch unit is related to traffic handling of the ASA so in this case the CPU is at 46% due to how it handles traffic and the logging services (most being used by the dispatch unit)
44% is not something to be scared of, unless you were on 2 % this morning and suddenly you go up to 46%
For Networking Posts check my blog at http://laguiadelnetworking.com/
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thanks Julio,
We are running DPI default and basic inspection setting as below.
I will keep monitor the CPU usgae and traffic on ASA to see if got any sudden change.
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
class class-default
  set connection decrement-ttl
service-policy global_policy global
prompt hostname context
That's all you got to do now, keep an eye on it,
Cheers,
Julio Carvajal
669
