Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 - More than 1 public IP
Hello!
I got a little problem with our ASA 5510. Since last week we got 6 public ip?s from our ISP. Now my boss wants me to configure our ASA with these ip?s.
IP xxx.xxx.xxx.xxx should redirect the port 443 to a spezified server in our DMZ
IP yyy.yyy.yyy.yyy should redirect the port 25 to our mail server
IP zzz.zzz.zzz.zzz should redirect the port 443 to another server in our DMZ
Is this possible, and are there any documents about the configuration i have to do.
Thanks for your help.
Greetings
Timo
Green
Re: ASA 5510 - More than 1 public IP
Sure it's possible...
static (DMZ,outside) xxx.xxx.xx.xxx netmask 255.255.255.255
static (inside,outside) yyy.yyy.yyy.yyy netmask 255.255.255.255
static (DMZ,outside) zzz.zzz.zzz.zzz netmask 255.255.255.255
also need to allow ports in your access-list on outside interface
access-list extended permit tcp any host xxx.xxx.xxx.xxx eq 443
access-list extended permit tcp any host yyy.yyy.yyy.yyy eq 25
access-list extended permit tcp any host zzz.zzz.zzz.zzz eq 443
access-group in interface outside
Community Member
Wow, thanks for your fast reply.
And how is it possible to define the ip adresses on the outside interface. I think this should be something like:
ip adress abc.def.ghi.jkl 255.255.255.248
Timo
Green
Yes,
config t
interface e0/0 (or whatever interface it is)
ip addr
please rate if these help
162
