Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA 5510 MPLS connection
We have MPLS connection to remote server in different state. Both locations are running ASA 5510, is there any way i can check what applications are running through MPLS network on firewall and what is total usage per month.  If yes, how can i do that.  I am not advance user on firewalls so thanks in advance.
Re: ASA 5510 MPLS connection
You can connect an ASA to an MPLS network, however the ASA won't understand or talk MPLS.
You can use the ASA to check the traffic as you would in any other scenario.
Please clarify exactly what your trying to accomplish.
Federico.
Thanks for replying Federico,
Is there any way i can check what appplications are running trhough mpls and also would like to now the traffic.
As I told you, you can check statistics for the traffic that goes through the ASA for example.
There are ways to log, capture, monitor the traffic that flows through the ASA filtered on a certain IP for example.
What kind of information do you expect to see?
Federico.
391
