Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 NAT Issue
I am phasing out a Sonicwall 1260 with an ASA 5510 cluster. The Sonicwall uses PAT with a single public IP.
Email, VPN, ftp and other services are coming in through the wan interface and are port forwarded to their destination servers on the lan.
Today I was having an issue with getting services through the asa 7.2 os and the ACL kept blocking the connections.
I believe its down to the fact that the outside ip is the same as the IP the connections are going to eg the mx record points to the outside ip and any connections on port 25 are being dropped.
Am I doing something wrong or does the asa want to pat the internal network to one ip and have external connections come in on a seperate ip?
The .128 mask is down to the ISP and their setup and I dont have that many addresses available!
Any help appreciated
interface Ethernet0/0
description Link to LAN
speed 100
duplex full
nameif inside
security-level 100
ip address 192.1.1.252 255.255.255.0 standby 192.1.1.253
interface Ethernet0/1
description Link to ICE
speed 100
duplex full
nameif outside
security-level 0
ip address x.x.x.10 255.255.255.128 standby x.x.x.31
access-list outside_in extended permit tcp any host x.x.x.10 eq smtp
access-list outside_in extended permit icmp any any echo-reply
access-list outside_in deny ip any any log
access-group outside_in in interface outside
global (outside) 1 interface
nat (inside) 1 192.1.1.0 255.255.255.0
static (inside,outside) tcp x.x.x.10 smtp 192.1.1.12 smtp netmask 255.255.255.255
1 ACCEPTED SOLUTION
Green
Re: ASA 5510 NAT Issue
Change your static commands to include the keyword "interface" instead of x.x.x.10.
ex.
static (inside,outside) tcp interface smtp 192.1.1.12 smtp netmask 255.255.255.255
Please rate helpful posts.
Green
ex.
Community Member
I'll try this out next week when I'm back on site. Legend if it works.
I'll let you know
Community Member
And I believe that your acl should be like this,
access-list outside_in extended permit tcp any host 192.1.1.12 eq smtp
Green
No, your acl is correct as you had it.
142
