ASA 5510 No Internet Connection on the inside Interface
Hi all,
so i have a ASA 5510.
The ASA is Connect with the Internet through PPOE DSL MODEM
The outside Interface get an IP
The Inside Interface get through DHCP from the ASA the Internet DNS SERVER (T-Online)
But the HOST do not connect to the Internet because the DNS Server is timed out
Here my Config:
ciscoasa> ena
Password: *******
ciscoasa# show run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
enable password xxx
passwd xxx
names
interface Ethernet0/0
nameif outside
security-level 0
pppoe client vpdn group T-Online
ip address pppoe setroute
interface Ethernet0/1
shutdown
no nameif
security-level 100
no ip address
interface Ethernet0/2
nameif inside
security-level 100
ip address 172.20.0.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server 217.5.100.185
name-server 217.5.100.186
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
<--- More --->
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 <ip of the outside interface> 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 172.20.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
<--- More --->
ssh timeout 5
console timeout 0
vpdn group T-Online request dialout pppoe
vpdn group T-Online localname <t-online username>
vpdn group T-Online ppp authentication pap
vpdn username <t-online username> password xxx
dhcpd address 172.20.0.100-172.20.0.200 inside
dhcpd dns 217.5.100.185 217.5.100.186 interface inside
dhcpd enable inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
<--- More --->
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:b28f45c98568fb8d01293cf71256fa82
<--- More --->
: end
ciscoasa#
I Think this must be a NAT/ACL Problem but when i configure nat the same Problem still exists
CAn someone Help me ?
Red
Hi Philipp,
It definitely seems to be a NAT issue, you would need to add this:
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
If it still does not work, please reboot the modem and the ASA once and then check again.\
Hope that helps,
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Hi Varun,
I guess you oversighted that ASA version is 8.4 :-).
Philipp,
For the new version try this...
object network obj_any
   subnet 0.0.0.0 0.0.0.0       --> You can replace 0/0 with your internal subnet.
   nat (inside,outside) dynamic interface
For more information on pre/post 8.3 syntax changes, refer the below link...
https://supportforums.cisco.com/docs/DOC-9129
hth
MS
Red
Oh yess, definitely, thanks. I jsut didnt see any nat statement in there, n might have overlooked the one you specified
Cheers,
Varun
Re: ASA 5510 No Internet Connection on the inside Interface
OK i see it :-)
But when i config this the Problem still exist :-(
New Config:
iscoasa# show run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
enable password xxx
passwd xxx
names
nameif outside
security-level 0
shutdown
no nameif
security-level 100
no ip address
nameif inside
security-level 100
ip address 172.20.0.1 255.255.0.0
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
object network Testpc
host 172.20.100.1
access-list inside_in extended permit ip any interface outside
access-list inside_access_in extended permit ip 172.20.0.0 255.255.0.0 interface outside
access-list inside_access_in extended permit ip object Testpc interface outside
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
arp timeout 14400
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 87.139.227.44 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn username password xxx
dhcpd address 172.20.100.1-172.20.100.200 inside
dhcpd enable inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:3b1058e17ecd9f9dd895841e0cdf9688
: end
ciscoasa#
The new acls are a try to solve this output from the ASDM Logging:
443    Deny TCP (no connection) from 172.20.100.1/50142 to 172.20.0.1/443 flags FIN ACK  on interface inside
Update:
I have remove the acls so that only "Lower Interface" rule is working
It seems that the connection to the DNS Server is established but than theconnection is closed  with "Teardown" befor the information is transmittet.
All packets are translatet but is not working
Log Entrys:
217.100.5.185|   53|172.20.100.1 |63320|Teardown UDP connection 1552 for outside:217.100.5.185/53 to inside:172.20.100.1/63320 duration 0:02:07 bytes 129
217.100.5.186|   53|172.20.100.1 |63320|Teardown UDP connection 1551 for outside:217.100.5.186/53 to inside:172.20.100.1/63320 duration 0:02:08 bytes 172
172.20.100.1 |54829|217.100.5.186|   53|Built outbound UDP connection 1562 for outside:217.100.5.186/53 (217.100.5.186/53) to inside:172.20.100.1/54829 (ISP given IP/29049)
172.20.100.1 |54829|217.100.5.185|   53|Built outbound UDP connection 1561 for outside:217.100.5.185/53 (217.100.5.185/53) to inside:172.20.100.1/54829 (ISP given IP/29049)
172.20.100.1 |54829|87.139.227.44|29049|Built dynamic UDP translation from inside:172.20.100.1/54829 to ISP given IP/29049
Update:
The Problem is caused @ the outside Interface
Incomming Packtes ar droped through an outside acl.
The packet flows is broken @ an acl from the outside to the inside
When i openthe wall the nat drop the packet -.........
Hello Philiopp,
Please add the following access-list
access-list inside_in line 1 permit ip any any
Then provide me the following outputs:
- packet-tracer input inside tcp 172.20.1.15 1025 4.2.2.2 80
- fixup protocol icmp
-Try to ping from the PC 87.139.227.44 and let me know the result
-Ping for the ASA to 4.2.2.2
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Thanks ,
here the Output you need:
ciscoasa(config)#packet-tracer input inside Tcp 172.10.1.15 1025 4.2.2.2 80
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 172.10.1.15/1025 to 87.139.227.44/22793
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 294, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
ciscoasa(config)# ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/68/70 ms
ciscoasa(config)#
Ping from PC:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\Technik>ping 87.139.227.44
Ping wird ausgeführt für 87.139.227.44 mit 32 Bytes Daten:
Zeitüberschreitung der Anforderung.
Ping-Statistik für 87.139.227.44:
    Pakete: Gesendet = 4, Empfangen = 0, Verloren = 4
    (100% Verlust),
C:\Users\Technik>
So the ASA does have internet connectivity..
Did you add the command fixup protocol ICMP??
Yes, i have enter this command but nothing chnage. I have activate vpn over ssl as a test, it works fine but the inside host has no connection to the outside.
The new config you posted- ASA missing DNS IPs for hosts.
dhcpd dns 217.5.100.185 217.5.100.186 interface inside  --> Add this to ASA
Also, remove access-group inside_access_in in interface inside  (you add later if required)
Try with this and see how it goes. If any issues, try to browse using IP instead of DNS name.
Thx
MS
3028
