Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 not working passive FTP, Active works, help!
I inherited an issue on a production firewall, pertaining to a new FTP rule they put in.  The config is a bit out of order from what I’d normally do, I’m guessing due to being put in by GUI and not CLI.  Here is what is pertaining to the FTP, I believe:
object network XXXXX
 host In.ter.nal.IP
Creating the FTP service group:
object-group service DM_INLINE_TCP_1 tcp
 port-object eq ftp
 port-object eq ftp-data
Granting Server access to the service:
access-list INTERNET extended permit tcp any object XXXXX object-group DM_INLINE_TCP_1
Creating a 1:1 NAT for Server:
 nat (inside,outside) static Ex.ter.nal.IP
And granting the INTERNET access list access to the outside connection:
access-group INTERNET in interface outside
Then the parts pertaining to passive FTP are here:
policy-map global_policy
 class inspection_default
  inspect ftp
ftp mode passive
So I can hit it active, but not passive.  Passive fails to connect the data stream on whatever port it requests it from.  Suggestions?
VIP Purple
The command "ftp mode passive
The command "ftp mode passive" doesn't relate to your problem. It's for the ASA being the FTP-client.
In the service-object-group, you don't need ftp-data. With a correct config, the data-port will be allowed dynamically.
So, why doesn't it work. My first assumption would be that you have not applied the policy-map to the ASA:
service-policy global_policy global
Community Member
service-policy global_policy global is in there, sadly.  Sorry, I should have posted that as well...
I'm unfamiliar with what ftp-data even does; I've never used it before.
My other thought is that I have this:
but no inbound listed of any kind.  Typically, this firewall was mainly used for web servers, so I'm thinking there is the potential that no inbound was ever configured.  Then again, I can get in on Active FTP.
The interfaces show this:
interface Ethernet0/0
 description Internet Interface
 nameif outside
 security-level 0
 ip address Ex.ter.nal.IP
interface Ethernet0/1
 nameif inside
 security-level 100
 ip address In.ter.nal.IP
Am I on the right track?
VIP Purple
what is the output of "sh
  1. what is the output of "sh service-policy inspect ftp"?
  2. Is passive FTP working when the client is also on the inside?
Community Member
Right now, I only have the
Right now, I only have the config to work with, but both passive and active work inside the firewall, so it's not a server issue.
I feel like maybe it is the service group DM_INLINE_TCP_1.  As you said, ftp-data is not needed, so we could feesably ditch the object group all together and instead do a line like:
access-list INTERNET permit tcp any object SERVERNAME eq ftp
VIP Purple
yes, that's all that is needed for access-control to the server.
Community Member
OK, so I deleted the DM
OK, so I deleted the DM_INLINE_TCP_1 from the ACL, removed the service group, then added:
Same result as before, I can get in active, but not passive.  I'm really stumped...
They are running version 8.4 (2), are there known issues with FTP?
Additionally, they want to run SSL for the username and password, but not for the data connection...any thoughts on that?
