ASA 5510 post and pre 8.3 NATting and ACLs
In the near future I plan on updating all of my firewalls to 8.4, currently we're on a mix of 8.0 and 8.2. I've heard that if your equipment is on 8.2 there's an auto-conversion feature when upgrading to 8.3. However, I do not want to rely on that and am trying my hand at re-writing the NAT and ACLs myself. Attached is my pre 8.3 ASA 5510 config (santized) and a document that shows the particular sections pre 8.3 and what I think they should be after the upgrade.
Can someone take a look and let me know if these look right?
Everyone's tags (5)
1 REPLY
VIP Purple
I didn't go through your complete config to check it but some hints:
1) for your NAT-Excemption, you can use object-groups. With that you only need one line per interface-combination.
2) There is no nat-control anymore. If there is no nat-command between a particular set of interfaces the packets are just routed between the interfaces.
3) Keep in mind that the new rules are processed top down. By default your global nat-statements come first, then the object-nat.
With that, your config could be more optimized.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
478
