Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 (Primary unit) slow throughput
After I installed the asa5510 with failover feature, I found that the ftp/netbios download traffic on primary unit was about 1.2Mb, so I forced the secondary unit to takeover these traffic instead of primary unit, I found that the throughtput was about 50Mb, Please anyone help me to identify this problem.
1. Outside and inside interfaces don't have any error.
2. When connect PC directly to ASA on outside and inside interface and testing download via ftp/netbios, the problem still occured.
1 ACCEPTED SOLUTION
Re: ASA 5510 (Primary unit) slow throughput
pls check speed & duplex
Try to set them manually.
Community Member
Hi alekseev,
Thanks for your help, yesterday I tried to change interface inside with speed & duplex auto and forced outside interface with speed100 duplexFull, so it work, but I don't know why the secondary unit has work without manually configured on both interfaces. Could you explain me?
1028
