ASA 5510 redudant interface
I have configured redundant interface on ASA 5510
interface Redundant1
description *** INSIDES NETWORK ***
member-interface Ethernet0/1 (This is a 1000Mbps Port)
member-interface Ethernet0/2 (This one is 100Mbps)
no nameif
no security-level
no ip address
interface Redundant1.10
vlan 10
nameif inside
security-level 100
ip address 192.168.1.168 255.255.255.0
redundant-interface redundant 1 active-member ethernet 0/1
Interface Ethernet0/1 ---- Connected to --- Primary Core Switch Interface Gi0/30
Interface Ethernet0/1 ---- Connected to --- Secondary Core Switch Interface Gi0/30
Then... i issue following command and its OK!
ASA5510# show interface redundant 1 detail
Interface Redundant1 "", is up, line protocol is up
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
        Input flow control is unsupported, output flow control is off
        Description: *** INSIDES NETWORK ***
        Available but not configured via nameif
        MAC address 7081.0570.e37d, MTU not set
        IP address unassigned
        8200483 packets input, 2109574889 bytes, 0 no buffer
        Received 99254 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        11878 L2 decode drops
        10309739 packets output, 9085407428 bytes, 0 underruns
        0 pause output, 0 resume output
        0 output errors, 0 collisions, 7 interface resets
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (510/249)
        output queue (blocks free curr/low): hardware (510/244)
  Topology Information:
        This interface, a , is connected
        with Ethernet0/0, a .
  Control Point Interface States:
        Interface number is 8
        Interface config status is active
        Interface state is active
  Redundancy Information:
        Member Ethernet0/1(Active), Ethernet0/2
        Last switchover at 13:54:02 IST Aug 15 2012
Then i have shutdown Primary core switch Gi0/30 Interface and Issued above command again
  Hardware is i82546GB rev03, BW 100 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        8176236 packets input, 2102449428 bytes, 0 no buffer
        Received 98539 broadcasts, 0 runts, 0 giants
        11682 L2 decode drops
        10278568 packets output, 9060503327 bytes, 0 underruns
        0 output errors, 0 collisions, 4 interface resets
        input queue (blocks free curr/low): hardware (510/254)
        output queue (blocks free curr/low): hardware (510/255)
        Member Ethernet0/2(Active), Ethernet0/1
        Last switchover at 13:45:10 IST Aug 15 2012
It's tranferd corectly then i no shut and back to normal Primary core switch Gi0/30 Interface again, BUT  redundant interface no revert back.
I issued this command again BW remain 100Mbps
I did manualy shut down and no shut the secondary core switch interface Gi0/30 Its changed correctly to 1000Mbps .
pls tell some one why it's not automatically transer active interface and speed ???
Everyone's tags (4)
1 ACCEPTED SOLUTION
I remember that being there by design. Fail back or Preempt was not supported in case of Redundant interfaces and is actually not a good idea in terms of stability. You dont want the interface failover to happen again when the active interface comes back up. In order to force the 1000Mbps interface to be active, you can manually do so by the command 'redundant-interface 1 active
Hope that Helps
Zubair
1 REPLY
Hope that Helps
Zubair
527
