Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
asa 5510 - Routing failed (inside to dmz)
Hi All,
I'am facing somehing not very hard but i cannot figure out how to solve it !
The actual configuration let me access :
- From Inside to internet
- From Outside to DMZ (one web server)
But i cannot access my web server from the inside interface, i get the following error :
"Routing failed to locate next hop for TCP from inside:192.168.1.2/1224 to dmz:x.y.50.144/8080".
I get my main route from the DHCP server (ip address dhcp setroute). I don't know which static route but i guess, i have to add one in order solve it.
BTW, how do i check for my actual route with ASDM ?
Thanks for your kind help,
-sh run---------
: Saved
ASA Version 8.0(2)
hostname ciscoasa
domain-name asaname
names
interface Ethernet0/0
nameif inside
security-level 100
interface Ethernet0/1
nameif outside
security-level 0
interface Ethernet0/2
nameif dmz
security-level 50
ip address 10.30.30.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.7.88 255.255.255.0
management-only
passwd xxx
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
domain-name hosting.scala.eu
access-list outside_access_in extended permit tcp any interface outside
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 200 interface
nat (inside) 200 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface 8080 10.30.30.30 8080 netmask 255.255.255.255
static (dmz,inside) 10.30.30.30 x.y.50.144 netmask 255.255.255.255
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.255 inside
http 192.168.7.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.7.89-192.168.7.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
: end
1 ACCEPTED SOLUTION
Green
Re: asa 5510 - Routing failed (inside to dmz)
Is x.y.50.144 the public address of the webserver? If so, I would do something like this.
static (dmz,inside) x.y.50.144 10.30.30.30 netmask 255.255.255.255
Also, take the route out that you added.
Green
You need to add a route on the ASA to x.y.50.144.
route dmz x.y.50.144 255.255.255.255
Community Member
So i added "route dmz x.y.50.144 255.255.255.255 10.30.30.1 1"
Works better, i mean, now, the message is more informal but i still cannot access web server, the only infomation i have is "Built outbound TCP connection 1978 for dmz:x.y.50.144/8080 (10.30.30.30/8080) to inside:192.168.1.2/1225 (192.168.1.2/1225)" then "Teardown TCP connection 1978 for dmz:x.y.50.144/8080 to inside:192.168.1.2/1225 duration 0:00:30 bytes 0 SYN Timeout".
The result of a show route give me that:
Gateway of last resort is v.w.50.254 to network 0.0.0.0
C x.y.50.0 255.255.255.0 is directly connected, outside
C 10.30.30.0 255.255.255.0 is directly connected, dmz
C 192.168.7.0 255.255.255.0 is directly connected, management
C 192.168.1.0 255.255.255.0 is directly connected, inside
d* 0.0.0.0 0.0.0.0 [1/0] via v.w.50.254, outside.
Green
Community Member
Well ..... PEEEERFECT ! Yes, it is the web server public address. So i took out the route you gave me and added "static (dmz,inside) x.y.50.144 10.30.30.30 netmask 255.255.255.255 "
Thank you !
I have "static (dmz,inside) 10.30.30.30 x.y.50.144 netmask 255.255.255.255" in my conf, do i have to remove it ?
Green
Glad it worked. I would remove the other static.
Please rate posts you found helpful.
648
