ASA 5510 SLA monitor
I have 2 outside connections one of which works as a backup connection. I am trying to setup SLA monitor so that when primary fails, the secondary connection takes over. However I never get connected to the primary connection after reboot, the backup connection is active after reboot. I configure:
sla monitor 1
type echo protocol ipIcmpEcho x.x.x.x interface INET
num-packets 3
timeout 1000
frequency 20
sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
route INET 0.0.0.0 0.0.0.0 89.x.x.73 1 track 1
at this moment two route config exist:
I delete the:
no route INET 0.0.0.0 0.0.0.0 89.x.x.73
Now this works as it should. However, once I reload  (after write), the backup connection is active.
The only way it works even after reload is when in sla monitor 1:
type echo protocol ipIcmpEcho 89.x.x.73 interface INET
ie. If I am trying to ping the gateway.
Also I have noticed if one connection is active eg INET: ping INETSDSL 8.8.8.8 makes no response however ping INET 8.8.8.8 works fine. And if backup connection is active, ping INET 8.8.8.8 gives no result but ping INETSDSL 8.8.8.8 works fine.
Some config details:
route INETSDSL 0.0.0.0 0.0.0.0 10.x.x.x 254
sla monitor 1
num-packets 3
timeout 1000
frequency 20
sh ver:
Cisco Adaptive Security Appliance Software Version 8.2(1)11
Device Manager Version 6.2(5)
Any ideas how to make it work?
Everyone's tags (5)
Re: ASA 5510 SLA monitor
Hi Bro
The default gateways should look like this instead
route INETSDSL 0.0.0.0 0.0.0.0 10.x.x.x 100
Note: 100 is the metric
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
And is it ok that I cannot do ping INETSDSL 8.8.8.8 when primary connection is active?
1392
