ASA 5510 ssh issue
I am not able access my asa5510 through ssh. I was to do this before but now when i try this wiht putty the error says"Server unexpectedly closed network connection".
On ASA SSH ver. 2 is allowed. Please have look at the "show ssh" on asa:
ASA# show ssh
Version allowed: 2
0.0.0.0 0.0.0.0 outside
0.0.0.0 0.0.0.0 inside
0.0.0.0 0.0.0.0 failover
Please help. Thanks
2 ACCEPTED SOLUTIONS
ASA 5510 ssh issue
What version are you running ? There's a bug in 8.4.1
Here you have a Cisco document about ssh bugs in Cisco ASA
https://supportforums.cisco.com/docs/DOC-16513
PLease rate if it helps. Kind reagrds
ASA 5510 ssh issue
Maybe you just have to re-generate RSA keys.
Can you access the ASA using telnet?  If you can, try the steps described in the following link: http://bit.ly/zisKZ1
ASA 5510 ssh issue
Also i have tested this on different computers.
ASA 5510 ssh issue
ASA 5510 ssh issue
ASA 5510 ssh issue
rebooting the device fixed the issue.
907
