ASA 5510 - SSO for OWA using WebVPN
Is it possible to configure a SSO for OWA (Form Based) on the ASA 5510?
Please Advise,
Ziv.
Silver
Re: ASA 5510 - SSO for OWA using WebVPN
This can be done right from the version 12.4(11)T. Check if the URL http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htwebvpn.html helps you.
Ziv,
I'm using 8.0(3). What I did was set up the SSO config for OWA under the group policy.
Configuration > Clientless SSL VPN > Group Policy. Select the group policy you're using (Probably default) and select Edit > More Options > Single Sign-On. What I did was set up a net block that I was using to push the creds to. If you want to use the URI, there's a guide in the 8.0 Config. Hope this helps!
-Fritzy
908
