Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5510 telnet/ssh access problem
I have an ASA 5510 running ver 7.0.7. I have an L2L tunnel connecting to it. I am trying to manage the ASA via ssh or telnet to the inside interface from the L2L remote end and not able to.
I have the command management-access inside configured as well as allowing telnet and ssh to the inside from any where:
telnet 0 0 inside
ssh 0 0 inside
I am still not able to get to it via ssh or telnet. Http and icmp work fine.
When looking at the encrypts and decrepts for the ipsec sa:
#pkts encaps: 26, #pkts encrypt: 26, #pkts digest: 26
#pkts decaps: 64, #pkts decrypt: 64, #pkts verify: 64
indicating my telnet or ssh packets are decrypted but not encrypted. The show asp table vpn-context details shows corresponding data:
CBS-ASA-5510# sh asp table vpn-context d
VPN Ctx = 0067441000 [0x04051168]
Peer IP = 2.0.2.105
State = UP
Flags = DECR+ESP
SA = 0x15855031
SPI = 0x875427A6
Group = 0
Pkts = 64
Bad Pkts = 0
Bad SPI = 0
Spoof = 0
Bad Crypto = 0
Rekey Pkt = 1
Rekey Call = 1
VPN Ctx = 0064172784 [0x03D332F0]
Peer IP = 2.0.2.105
State = UP
Flags = ENCR+ESP
SA = 0x1586F4A9
SPI = 0x7989DFA2
Group = 0
Pkts = 26
Bad Pkts = 0
Bad SPI = 0
Spoof = 0
Bad Crypto = 0
Rekey Pkt = 1
Rekey Call = 1
However in the asp crypto classifier, I do not see my packets:
out id=0x34f4f80, priority=70, domain=encrypt, deny=false
hits=26, user_data=0x3d332f0, cs_id=0x38a1908, reverse, flags=0x0, protocol=0
src ip=192.168.77.0, mask=255.255.255.0, port=0
dst ip=2.0.2.105, mask=255.255.255.255, port=0
in id=0x3d36ac0, priority=69, domain=ipsec-tunnel-flow, deny=false
hits=26, user_data=0x4051168, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip=2.0.2.105, mask=255.255.255.255, port=0
dst ip=192.168.77.0, mask=255.255.255.0, port=0
Is this an existing bug or am I missing something?
Re: ASA 5510 telnet/ssh access problem
Make sure you have in fw this statement
management-access
e.i for interface name inside
fw(config)#management-access inside
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/mr.html#wp1578189
Rgds
Jorge
it is there:
https access to the inside interface works.
Sorry.. read fast your post.. I have to say it could be a bug discribed here, even though you can ping fine but telnet and ssh is affected by this bug which is open caveats in 7.0.7
bug details CSCej04099
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCej04099
open in 7.0.7
http://www.cisco.com/en/US/customer/docs/security/asa/asa70/release/notes/rn707.html#wp339364
Thank you for the response. I was looking into the bug and I am not sure if it applies as there is not static tht includes the inside interface address and it is included in the nat 0. Upon furthr searching into the bug kit, I actually found the bug that must be a match:
CSCsj53102
SSH/Telnet access through VPN tunnel to management interface not working
Thank you very much for the input.
958
