ASA 5510 traffic from inside to outside
I'm working on a basic configuration of a 5510 ASA.
inside network of 192.168.23.0 /24
outside network 141.0.x.0 /24
config is as follows:
interface Ethernet0/0
 nameif OUTSIDE
 security-level 0
 ip address 141.0.x.0 255.255.255.0
interface Ethernet0/1
 nameif INSIDE
 security-level 50
 ip address 192.168.23.1 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list OUTSIDE_access_in extended permit icmp any any
access-list OUTSIDE_access_in extended permit tcp any interface OUTSIDE eq https
access-list INSIDE_access_in extended permit icmp any any
global (OUTSIDE) 1 interface
nat (INSIDE) 1 192.168.23.0 255.255.255.0
access-group OUTSIDE_access_in in interface OUTSIDE
access-group INSIDE_access_in in interface INSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 141.0.x.57 1
In the LAB When I plug a laptop into the outside interface with address 141.0.x.57 I can ping it from a laptop from the inside interface and I can even access the IIS page. However, when I connect the ISP's firewall into the outside interface with the same address that I used the testing laptop with, I cannot seem to be able to access the outside world.
I can ping from the ASA's outside interface (x.58, to the ISP's x.57), but I cannot ping from the inside 192.168.23.x to it or access anything.
So traffic between inside and outside interface is not going through when in live setup. However, when in the lab it works fine.
Any ideas please?
1 ACCEPTED SOLUTION
VIP Purple
The output in Phase7 still
The output in Phase7 still looks very strange. Please upgrade your ASA before testing any further. 8.2(1) was a horrible release.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Purple
Can you ping from the ASA to
  1. Can you ping from the ASA to an internet-IP like 8.8.8.8?
  2. Can you ping the IP .44.57 from an inside system?
And:
The line "access-list OUTSIDE_access_in extended permit tcp any interface OUTSIDE eq https" is probably not needed in your setup as there is no static NAT for an internal server.
Hi Karsten, 1. From ASA
Hi Karsten,
1. From ASA outside interface I can ping 8.8.8.8
2. From inside interface I cannot ping x.57
However, in the lab when I have a laptop plugged into the outside interface with the x.57, i can ping it. I've statically assigned the laptop with x.57, correct subnet, and a default GW of the ASA outside interface of 58.
Do I need to setup a static NAT?
This setup is for public internet where I will have devices on the inside interface pick up a dhcp address of 192.168.23.x accessing the internet (ISP's Juniper 1x.0.x.57)
VIP Purple
That shows that your external
That shows that your external setup is fine. But it's strange that you can ping your external PC but not the provider-device.
Make sure that you have the icmp-inspection active:
policy-map global_policy
  class inspection_default
   inspect icmp
Please show the output of the following command:
packet-tracer input INSIDE 192.168.23.10 8 0 144.0.44.47
Version of FW:Cisco Adaptive
Version of FW:
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.3(1)
Output of Packet-Trace Command is:
SDH-PUBLIC-ASA(config)# packet-tracer input INSIDE icmp 192.168.23.10 8 0 1xpacket-tracer input INSIDE icmp 192.168.23.10 8 0 141.$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   141.0.x.0      255.255.255.0   OUTSIDE
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
  inspect icmp
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (INSIDE) 0 192.168.23.0 255.255.255.0
  match ip INSIDE 192.168.23.0 255.255.255.0 OUTSIDE any
    identity NAT translation, pool 0
    translate_hits = 104, untranslate_hits = 0
Dynamic translate 192.168.23.10/0 to 192.168.23.10/0 using netmask 255.255.255.255
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
    translate_hits = 107, untranslate_hits = 0
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 141, packet dispatched to next module
Result:
input-interface: INSIDE
input-status: up
input-line-status: up
output-interface: OUTSIDE
output-status: up
output-line-status: up
Action: allow
VIP Purple
obviously you didn't show us
obviously you didn't show us the complete NAT-config:
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
You have to correct you NAT-Exemption (nat 0).
And you really should upgrade your ASA to at least 8.2.(5).
That was the complete NAT in
That was the complete NAT in the OP. Since then I rebooted the FW and it picket up the original config with a different NAT.
I have run the command with the same NAT config now on the OP.
Apologies for the confusion..
Sorry, I've made the
Sorry, I've made the following change to Nat
And here is the result of the same packet-trace command:
SDH-PUBLIC-ASA(config)# packet-tracer input INSIDE icmp 192.168.23.10 8 0 141.$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
    dynamic translation to pool 1 (141.0.x.58 [Interface PAT])
    translate_hits = 66, untranslate_hits = 0
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 286, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
VIP Purple
Hi Karsten, Many thanks for
Hi Karsten,
Many thanks for your help mate.
I've upgraded both the image and ASDM and it's flying.
config looks like goodproblem
problem can be like mac filtering from provider side
VIP Purple
That seems very unlikely to me. With this NAT-config, the pings from internal PC and the ASA should look completely the same on L2/L3 for the provider-router.
If the ASA is not running the latest 8.2 code, an update should also be done. There have been far too many strange bugs in the ASA.
Hi Tagir, Thought of this and
Hi Tagir,
Thought of this and used another laptop to connect straight into ISP's 44.57 and was able to access the internet. If it was MAC filtering, then laptop test should've failed.
129
