Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5510 - traffic from LAN to LAN (via public IP) is denied
On my network, I have an ASA 5510 with this configuration :
                    WWW
                    ISP Bridge
          (outside Interface : 129.*.*.*)
               ASA 5510
          (inside interface : 192.168.1.1)
               Local Network
      (192.168.1.5 to 192.168.1.200)
There is a rule to redirect access from the outside on port 80 to a specific host in my LAN.
When I try to access this specific host with the public IP (for instance : http://129.*.*.* ) from the outside : no problem.
But when I try to access from the inside network the same host with the public IP (for instance : http://129.*.*.* ) : the ASA recognize that this is the IP of his "outside interface", redirect this traffic to the LAN but deny the connection...
Erro Level 3 :
192.168.1.122
50708129.*.*.*80TCP access denied by ACL from 192.168.1.122/50708 to Inside:129.*.*.*/80
Is there any solution to solve this problem?
Thank you.
1 REPLY
67
