Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5510 with Inside & DMz not working
i have here a ASA 5510 sec k9.
I build a Config with a DMZ,INSIDE and OUTSIDE Interface.
My Plan is to use the IP-Address of the OUTSIDE Interface with PORT to setup a HTTP Server In the DMZ
But my Config dossen´t work.
ANd I have no Plan why .....
The Inside Interface have to work normal. The Traffic to the Internet is TRiggert from Inside with Dynamic PAT
ciscoasa(config)# exit
ciscoasa# show run
: Saved
ASA Version 8.4(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address <Fix IP-ADDRESS> 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 50
ip address 192.168.50.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
object network Inside
subnet 192.168.20.0 255.255.255.0
object network DMZ
subnet 192.168.50.0 255.255.255.0
object network HTTP-Server
host 192.168.50.2
object service HTTP-SERVERDMZ
service tcp source eq 5081 destination eq 5081
access-list outside_access_in extended permit object HTTP-SERVERDMZ any object HTTP-Server
access-list DMZ_access_in extended permit object HTTP-SERVERDMZ 85.16.134.72 255.255.255.248 object HTTP-Server
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (outside,DMZ) source static any any destination static DMZ HTTP-Server service HTTP-SERVERDMZ HTTP-SERVERDMZ
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
access-group DMZ_access_in in interface DMZ
route outside 0.0.0.0 0.0.0.0 85.16.134.73 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
<--- More --->
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
<--- More --->
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
<--- More --->
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:273966ef24a6b1462a13d6d2dfe01279
ciscoasa#
Can someone Hep me
1 ACCEPTED SOLUTION
Ive seen this issue for a while now when people use the New NAT. There is no real need to translate the outside host to any any like you are doing it. First it comes the unstranslate and since the hosts on the outside are on a lower security level, there is no really need to translate them.
Bottom line, try this:
Change the service of the HTTP-SERVERMDZ to source instead of destination:
Then Create the nat as follows:
nat (dmz,outside) source static HTTP-Server interface service HTTP-SERVERDMZ HTTP-SERVERDMZ
Then the access list on the outside should permit the traffic to the Private IP
access-list outside permit tcp any host 192.168.50.2 eq 5081
With the configuration above you will be able to reach the server on the DMZ with the IP address of the outside interface of the firewall on port 5081.
If I am missing something, please feel free to tell, but from the config above you should be able to catch the drill.
Mike
Mike
Community Member
Ok reduce it to the Main problem:
NAT:
The IP ADRESS : 192.168.50.2/5081
Need acceeable over /5081
So the need a Mapping and a Access-List to allow it.
But no response from the Host in the DMZ
object network DMZ
host 192.168.50.2
Is the NAT Direction Correct ?
Mike
Mike
358
